Help - migrated to ZHA, but double press time is too short
I just migrated my mother’s room lights from Hue to ZHA (I needed one Hue light on ZHA to act as a Zigbee bridge for the new SONOFF TRV).
All lights, dimmers and scenes have been recreated in HA.
The dimmer is set to activate different scenes when power is single, double or triple pressed. With the Hue config it gave a couple of seconds to do this, but the HA automation double press or triple press is much faster - she can’t manage to turn on the 2nd and 3rd scenes programmed into the dimmer.
Can ZHA configure the double press speed, or is there a better way to achieve this?
regards
Steve
Steve – I don’t think so, but I’m surprised it changed. My experience is that the multi-press options come either from the device itself (in which case switching form Hue to ZHA shouldn’t matter) or from timers that are explicitly controlled in an automation (e.g. blueprints that simulate double-presses by checking how long it is since the last press). The latter can be adjusted, but I haven’t seen a way to adjust the former.
Maybe that’s helpful somehow. :frowning:
-David
Perhaps the hue app is not using the double, triple events but doing its own timing… I’ll try to figure out how to count single presses within a few seconds…
You can do that by setting an input_number to the current time. On the next press you check the difference in time, and if it’s short enough, then you have a double-click. There are several blueprints that are setup to do this. (E.g., check out the ones for the IKEA 5-button remotes.)
Thank’s for the input - I went through a few of the examples and came up with the following flow.
Note: When setting scenes on a Hue app the first is applied and then the subsequent ones as you press the button more times. There is no need to cancel the first scene (as far as I can tell).
The first block listens for two Hue v1 Dimmers and filters the on, off and dim events.
Second sets the scene name needed for turning off the lights.
Third block - the main logic
Receive the on event, count it and depending on the count set an appropriate scene. At the same time a timer allows for up to two seconds between presses and extends the time before the counter is reset.
Fourth block handles dim up / down
Fifth block activates the scene and records it in an input_text helper.
(The reason to record the scene is relevant in other rooms that also have a motion sensor - another flow detects motion and decides if a scene was manually selected or the default scene for occupancy has been set - it also simulates occupancy from simpler motion sensors).
[{"id":"46fa16f15dcf2549","type":"tab","label":"Julia's Room","disabled":false,"info":"","env":[]},{"id":"425c962d8a3d786a","type":"group","z":"46fa16f15dcf2549","name":"Set scene and record in helper","style":{"label":true,"stroke":"#0070c0","fill":"#bfdbef","color":"#000000"},"nodes":["5649c0d876eaed7e","d86e5f03346512b6","5fcb2e4b1f350e6c"],"x":114,"y":1299,"w":1012,"h":82},{"id":"c8cab6cf31b62f14","type":"group","z":"46fa16f15dcf2549","name":"Handle Dim Up / Down","style":{"label":true,"stroke":"#0070c0","color":"#000000","fill":"#bfdbef"},"nodes":["48c37311b5c7bc60","1337ee866d6e6a33","d522d7cc4747a1f1","4ce0f7bd241d8743","2d501b9cfdd53343","ce665e778fe1fd04","18426b735435e079","ae369fdad53e16a7","6bbd3819bebe819b","ef2f0c2a9e3f2fc4"],"x":114,"y":1119,"w":1012,"h":142},{"id":"129d0d0516de56a6","type":"group","z":"46fa16f15dcf2549","name":"Handle remote presses","style":{"stroke":"#0070c0","fill":"#bfdbef","label":true,"color":"#000000"},"nodes":["930c355e26f8436d","a0d055d17e9a1bf7","053da3a4f0ced8f1","8e65db0a744d7819","8dbbc120da4719e2","523f1c96e4b91155","8b2f364bb33ab9f3","cb3824e3e924e47c","98038cfbd03cbe35","779ecbd129ce78a4"],"x":114,"y":254,"w":992,"h":292},{"id":"5a2fa2c24e449024","type":"group","z":"46fa16f15dcf2549","name":"Handle single, double, triple..","style":{"stroke":"#0070c0","fill":"#bfdbef","label":true,"color":"#000000"},"nodes":["fe0a97b25e032259","4de63856ebe93d1c","3484a09efcfa8bbc","6cdf3cafdfd9dfac","ad31472c7f738996","f3f1bfb2f72278d1","6068caa500c5334c","fb16bc8c4b2821fd","8dff83c25297a6ef","0d908a5b55e9e99b","fa8a71dc810513f3","ce0201470c7aafc7","e9f0f7f94393bf01","684278d54ff0a324","76ced7aeaa5c73a5","fc265cc7b173bdca","68b86d6a9d93f24d","f5afe03b34da180c","ddf873bd78f6a986","29dd4566f610ee85","9cd80f7f358d3eda","e325d9429b2d388b"],"x":114,"y":699,"w":1002,"h":382},{"id":"1eda6a938c732555","type":"group","z":"46fa16f15dcf2549","name":"Handle Off","style":{"stroke":"#0070c0","fill":"#bfdbef","label":true,"color":"#001f60"},"nodes":["d9cc991fa3dcd8df","490fb76b60b29429","41d097f871f17764"],"x":114,"y":579,"w":1002,"h":82},{"id":"930c355e26f8436d","type":"server-events","z":"46fa16f15dcf2549","g":"129d0d0516de56a6","name":"Julia's Room Dimmer 1","server":"2be748d3.da7088","version":2,"eventType":"zha_event","exposeToHomeAssistant":false,"eventData":"{ \"device_ieee\": \"00:17:88:01:08:75:74:ea\" }","haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"}],"event_type":"","x":240,"y":380,"wires":[["a0d055d17e9a1bf7","053da3a4f0ced8f1"]]},{"id":"a0d055d17e9a1bf7","type":"debug","z":"46fa16f15dcf2549","g":"129d0d0516de56a6","name":"debug 201","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.event.command","targetType":"msg","statusVal":"","statusType":"auto","x":250,"y":320,"wires":[]},{"id":"fe0a97b25e032259","type":"counter","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"","init":"0","step":"1","lower":"","upper":"","mode":"increment","outputs":"1","x":360,"y":920,"wires":[["4de63856ebe93d1c"]]},{"id":"f5afe03b34da180c","type":"inject","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":960,"wires":[["fe0a97b25e032259"]]},{"id":"4de63856ebe93d1c","type":"switch","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"","property":"count","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"5","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":6,"x":510,"y":920,"wires":[["6cdf3cafdfd9dfac","6068caa500c5334c","ce0201470c7aafc7"],["3484a09efcfa8bbc","6068caa500c5334c","e9f0f7f94393bf01"],["ad31472c7f738996","6068caa500c5334c","684278d54ff0a324"],["0d908a5b55e9e99b","6068caa500c5334c","9cd80f7f358d3eda"],["fa8a71dc810513f3","6068caa500c5334c"],["f3f1bfb2f72278d1"]]},{"id":"3484a09efcfa8bbc","type":"debug","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"2 clicks","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":940,"y":780,"wires":[]},{"id":"6cdf3cafdfd9dfac","type":"debug","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"1 clicks","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":940,"y":740,"wires":[]},{"id":"ad31472c7f738996","type":"debug","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"3 clicks","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":940,"y":820,"wires":[]},{"id":"f3f1bfb2f72278d1","type":"debug","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"Otherwise","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"\"Otherwise\"","targetType":"jsonata","statusVal":"","statusType":"auto","x":940,"y":940,"wires":[]},{"id":"6068caa500c5334c","type":"trigger","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"wait up to 2 secs between each click ","op1":"","op2":"","op1type":"nul","op2type":"pay","duration":"2","extend":true,"overrideDelay":true,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":730,"y":1040,"wires":[["fb16bc8c4b2821fd"]]},{"id":"fb16bc8c4b2821fd","type":"change","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"reset counter","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":970,"y":1040,"wires":[["8dff83c25297a6ef"]]},{"id":"ddf873bd78f6a986","type":"link in","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"link in 4","links":["8dff83c25297a6ef","523f1c96e4b91155"],"x":215,"y":920,"wires":[["fe0a97b25e032259"]]},{"id":"8dff83c25297a6ef","type":"link out","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"link out 31","mode":"link","links":["ddf873bd78f6a986"],"x":1075,"y":1040,"wires":[]},{"id":"0d908a5b55e9e99b","type":"debug","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"4 clicks","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":940,"y":860,"wires":[]},{"id":"fa8a71dc810513f3","type":"debug","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"5 clicks","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":940,"y":900,"wires":[]},{"id":"44ab7d9d9f08f8d7","type":"comment","z":"46fa16f15dcf2549","name":"Trigger scenes by 1 to 5 presses. \\n each click will call a scene in sequence.","info":"","x":270,"y":180,"wires":[]},{"id":"ce0201470c7aafc7","type":"change","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"scene=nightlight","rules":[{"t":"set","p":"payload.scene","pt":"msg","to":"scene.julia_s_room_nightlight","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":740,"wires":[["76ced7aeaa5c73a5"]]},{"id":"e9f0f7f94393bf01","type":"change","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"scene=dimmed","rules":[{"t":"set","p":"payload.scene","pt":"msg","to":"scene.julia_s_room_dimmed","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":780,"wires":[["fc265cc7b173bdca"]]},{"id":"684278d54ff0a324","type":"change","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"scene=brighter","rules":[{"t":"set","p":"payload.scene","pt":"msg","to":"scene.julia_s_room_brighter","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":820,"wires":[["68b86d6a9d93f24d"]]},{"id":"5649c0d876eaed7e","type":"api-call-service","z":"46fa16f15dcf2549","g":"425c962d8a3d786a","name":"Set scene","server":"2be748d3.da7088","version":5,"debugenabled":false,"domain":"scene","service":"turn_on","areaId":[],"deviceId":[],"entityId":["{{payload.scene}}"],"data":"{ \"transition\": \"2\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"data","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":460,"y":1340,"wires":[["d86e5f03346512b6"]]},{"id":"d86e5f03346512b6","type":"api-call-service","z":"46fa16f15dcf2549","g":"425c962d8a3d786a","name":"Record Scene","server":"2be748d3.da7088","version":5,"debugenabled":false,"domain":"input_text","service":"set_value","areaId":[],"deviceId":[],"entityId":["input_text.julias_room_last_scene"],"data":"{\"value\": payload.scene}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1020,"y":1340,"wires":[[]]},{"id":"5fcb2e4b1f350e6c","type":"link in","z":"46fa16f15dcf2549","g":"425c962d8a3d786a","name":"link in 5","links":["41d097f871f17764","68b86d6a9d93f24d","76ced7aeaa5c73a5","fc265cc7b173bdca","e325d9429b2d388b"],"x":155,"y":1340,"wires":[["5649c0d876eaed7e"]]},{"id":"76ced7aeaa5c73a5","type":"link out","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"link out 32","mode":"link","links":["5fcb2e4b1f350e6c"],"x":1075,"y":740,"wires":[]},{"id":"fc265cc7b173bdca","type":"link out","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"link out 33","mode":"link","links":["5fcb2e4b1f350e6c"],"x":1075,"y":780,"wires":[]},{"id":"68b86d6a9d93f24d","type":"link out","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"link out 34","mode":"link","links":["5fcb2e4b1f350e6c"],"x":1075,"y":820,"wires":[]},{"id":"053da3a4f0ced8f1","type":"switch","z":"46fa16f15dcf2549","g":"129d0d0516de56a6","name":"","property":"payload.event.command","propertyType":"msg","rules":[{"t":"eq","v":"on_press","vt":"str"},{"t":"eq","v":"on_double_press","vt":"str"},{"t":"eq","v":"off_press","vt":"str"},{"t":"eq","v":"off_double_press","vt":"str"},{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"on_short_release","vt":"str"},{"t":"eq","v":"off_with_effect","vt":"str"},{"t":"eq","v":"on_triple_press","vt":"str"},{"t":"eq","v":"recall","vt":"str"},{"t":"eq","v":"off_triple_press","vt":"str"},{"t":"eq","v":"up_press","vt":"str"},{"t":"eq","v":"up_short_release","vt":"str"},{"t":"eq","v":"step","vt":"str"},{"t":"eq","v":"up_long_release","vt":"str"},{"t":"eq","v":"stop","vt":"str"},{"t":"eq","v":"up_hold","vt":"str"}],"checkall":"true","repair":false,"outputs":16,"x":430,"y":400,"wires":[[],[],["8e65db0a744d7819"],[],["523f1c96e4b91155"],[],[],[],[],[],[],[],["8dbbc120da4719e2"],[],[],[]]},{"id":"48c37311b5c7bc60","type":"switch","z":"46fa16f15dcf2549","g":"c8cab6cf31b62f14","name":"Dim up or down","property":"payload.event.params.step_mode","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":280,"y":1180,"wires":[["6bbd3819bebe819b"],["18426b735435e079"]],"outputLabels":["dim down","dim up"]},{"id":"1337ee866d6e6a33","type":"api-call-service","z":"46fa16f15dcf2549","g":"c8cab6cf31b62f14","name":"Dim Up","server":"2be748d3.da7088","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["{{payload.entity_id}}"],"data":"{ \"brightness_step\" : 10 , \"transition\" : 0.1 }","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":640,"y":1160,"wires":[["ce665e778fe1fd04"]]},{"id":"d522d7cc4747a1f1","type":"debug","z":"46fa16f15dcf2549","g":"c8cab6cf31b62f14","name":"debug 205","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1010,"y":1160,"wires":[]},{"id":"4ce0f7bd241d8743","type":"api-call-service","z":"46fa16f15dcf2549","g":"c8cab6cf31b62f14","name":"Dim Down","server":"2be748d3.da7088","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["{{payload.entity_id}}"],"data":"{ \"brightness_step\" : -10 , \"transition\" : 0.1 }","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":650,"y":1220,"wires":[["ae369fdad53e16a7"]]},{"id":"2d501b9cfdd53343","type":"debug","z":"46fa16f15dcf2549","g":"c8cab6cf31b62f14","name":"debug 206","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1010,"y":1220,"wires":[]},{"id":"ce665e778fe1fd04","type":"join","z":"46fa16f15dcf2549","g":"c8cab6cf31b62f14","name":"","mode":"custom","build":"merged","property":"payload","propertyType":"msg","key":"topic","joiner":",","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":810,"y":1160,"wires":[["d522d7cc4747a1f1"]]},{"id":"18426b735435e079","type":"ha-get-entities","z":"46fa16f15dcf2549","g":"c8cab6cf31b62f14","name":"","server":"2be748d3.da7088","version":0,"rules":[{"property":"entity_id","logic":"in_group","value":"light.julia_s_room","valueType":"str"},{"property":"state","logic":"is","value":"on","valueType":"str"}],"output_type":"split","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":470,"y":1220,"wires":[["4ce0f7bd241d8743"]]},{"id":"ae369fdad53e16a7","type":"join","z":"46fa16f15dcf2549","g":"c8cab6cf31b62f14","name":"","mode":"custom","build":"merged","property":"payload","propertyType":"msg","key":"topic","joiner":",","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":810,"y":1220,"wires":[["2d501b9cfdd53343"]]},{"id":"6bbd3819bebe819b","type":"ha-get-entities","z":"46fa16f15dcf2549","g":"c8cab6cf31b62f14","name":"","server":"2be748d3.da7088","version":0,"rules":[{"property":"entity_id","logic":"in_group","value":"light.julia_s_room","valueType":"str"},{"property":"state","logic":"is","value":"on","valueType":"str"}],"output_type":"split","output_empty_results":true,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":470,"y":1160,"wires":[["1337ee866d6e6a33"]]},{"id":"8e65db0a744d7819","type":"link out","z":"46fa16f15dcf2549","g":"129d0d0516de56a6","name":"link out 35","mode":"link","links":["490fb76b60b29429"],"x":955,"y":320,"wires":[]},{"id":"8dbbc120da4719e2","type":"link out","z":"46fa16f15dcf2549","g":"129d0d0516de56a6","name":"link out 36","mode":"link","links":["ef2f0c2a9e3f2fc4"],"x":915,"y":460,"wires":[]},{"id":"ef2f0c2a9e3f2fc4","type":"link in","z":"46fa16f15dcf2549","g":"c8cab6cf31b62f14","name":"link in 6","links":["8dbbc120da4719e2"],"x":155,"y":1180,"wires":[["48c37311b5c7bc60"]]},{"id":"523f1c96e4b91155","type":"link out","z":"46fa16f15dcf2549","g":"129d0d0516de56a6","name":"link out 37","mode":"link","links":["ddf873bd78f6a986"],"x":955,"y":360,"wires":[]},{"id":"8b2f364bb33ab9f3","type":"comment","z":"46fa16f15dcf2549","g":"129d0d0516de56a6","name":"On","info":"","x":1030,"y":360,"wires":[]},{"id":"cb3824e3e924e47c","type":"comment","z":"46fa16f15dcf2549","g":"129d0d0516de56a6","name":"Dim up/down","info":"","x":1010,"y":460,"wires":[]},{"id":"d9cc991fa3dcd8df","type":"change","z":"46fa16f15dcf2549","g":"1eda6a938c732555","name":"Off","rules":[{"t":"set","p":"payload.scene","pt":"msg","to":"scene.julia_s_room_off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":620,"wires":[["41d097f871f17764"]]},{"id":"490fb76b60b29429","type":"link in","z":"46fa16f15dcf2549","g":"1eda6a938c732555","name":"link in 7","links":["8e65db0a744d7819"],"x":155,"y":620,"wires":[["d9cc991fa3dcd8df"]]},{"id":"41d097f871f17764","type":"link out","z":"46fa16f15dcf2549","g":"1eda6a938c732555","name":"link out 38","mode":"link","links":["5fcb2e4b1f350e6c"],"x":1075,"y":620,"wires":[]},{"id":"98038cfbd03cbe35","type":"comment","z":"46fa16f15dcf2549","g":"129d0d0516de56a6","name":"Off","info":"","x":1030,"y":320,"wires":[]},{"id":"29dd4566f610ee85","type":"comment","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"Adjust wait according to user's ability >>>","info":"","x":380,"y":1040,"wires":[]},{"id":"9cd80f7f358d3eda","type":"change","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"scene=brightest","rules":[{"t":"set","p":"payload.scene","pt":"msg","to":"scene.julia_s_room_brightest","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":860,"wires":[["e325d9429b2d388b"]]},{"id":"e325d9429b2d388b","type":"link out","z":"46fa16f15dcf2549","g":"5a2fa2c24e449024","name":"link out 39","mode":"link","links":["5fcb2e4b1f350e6c"],"x":1075,"y":860,"wires":[]},{"id":"779ecbd129ce78a4","type":"server-events","z":"46fa16f15dcf2549","g":"129d0d0516de56a6","name":"Julia's Room Dimmer 2","server":"2be748d3.da7088","version":2,"eventType":"zha_event","exposeToHomeAssistant":false,"eventData":"{ \"device_ieee\": \"00:17:88:01:08:f1:62:c3\" }","haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"}],"event_type":"","x":240,"y":440,"wires":[["053da3a4f0ced8f1"]]},{"id":"2be748d3.da7088","type":"server","name":"Home Assistant","addon":true}]
I know this an older thread, but was there a solution outside of Node Red. Node Red is more a work around than a solution. I am asking now as the same issue seems to be present in Home Assistant. You can do multi-press on buttons, like double, triple, quad even 5 presses but you have to press it so quickly. If you miss be even half a second it resets.
Sorry to revive this thread, but this is still the exact issue that seems to be present using the native Home Assistant automation triggers.
You are right that NR is not core, but that said my NR flows have not let me down in two years.
