I am running Hass.io and using the mosquitto add on. This is working fine for my local connection and switches.
I have a mosquitto.conf file in the shared folder that it is reading. It looks like this
connection kappelt-gbridge
address mqtt.gbridge.io:8883
bridge_attempt_unsubscribe true
bridge_protocol_version mqttv31
cleansession true
remote_username gbridge-u795
remote_password MqttPasswordGoesHERE
remote_clientid gbridge-u795-as99df
bridge_capath /etc/ssl/certs/
bridge_tls_version tlsv1.2
topic gBridge/u795/+/+ both 0 "" ""
topic gBridge/u795/+/+/set both 0 "" ""
topic cmnd/# in 0 Basement2/ gBridge/u7/
topic stat/# out 0 Basement2/ gBridge/u7/
The add-on is reading the config as you can see from here
[INFO] No local user available
[INFO] Initialize Hass.io Add-on services
[INFO] Initialize Home Assistant discovery
[INFO] Start Mosquitto daemon
1551625451: mosquitto version 1.4.15 (build date 2018-03-04 15:14:46+0000) starting
1551625451: Config loaded from /etc/mosquitto.conf.
1551625451: *** auth-plug: startup
1551625451: ** Configured order: http
1551625451: Opening ipv4 listen socket on port 1883.
1551625451: Opening ipv6 listen socket on port 1883.
1551625451: Opening websockets listen socket on port 1884.
1551625451: Opening ipv4 listen socket on port 8883.
1551625451: Opening ipv6 listen socket on port 8883.
1551625451: Opening websockets listen socket on port 8884.
1551625451: Warning: Mosquitto should not be run as root/administrator.
1551625451: Connecting bridge kappelt-gbridge (mqtt.gbridge.io:8883)
1551625451: New connection from 192.168.1.137 on port 1883.
[INFO] found mqttuser1 on Home Assistant
1551625451: New client connected from 192.168.1.137 as MQTTGarageDoor_324fed7bd580 (c1, k60, u'mqttuser1').
1551625452: New connection from 172.30.32.1 on port 1883.
1551625453: Socket error on client <unknown>, disconnecting.
1551625453: New connection from 172.30.32.1 on port 1883.
[INFO] found homeassistant on local database
1551625453: New client connected from 172.30.32.1 as 95edf3a7-5a27-4093-9256-45c4c4027b7d (c1, k60, u'homeassistant').
1551625460: New connection from 192.168.1.121 on port 1883.
1551625461: New client connected from 192.168.1.121 as DVES_EF64C3 (c1, k10, u'mqttuser1').
You can see it connecting locally to 2 devices but it doesn’t connect to the bridge device.
I am following the instructions here https://doc.gbridge.io/integration/tasmota.html
If anyone has any ideas, I would be grateful.
