Help, my wall panel tablet stops talking tts via mqtt
Folks,
I have a nexus 9 htc tablet with the thanksmister wall panel running in kiosk mode.
I cant figure out why it stops responding to mqtt. Today even a reboot did not fix it, so it seams its a server thing.
I run the HA project .vdi container file for VirtualBox, all updates, mosquito. mqtt code unchanged between working and nonworking.
how do I best go about finding the issue?
thanks
since all I tried did not fix it, I rebooted the VM my HA is running in, that finally fixed the issue.
If no further posts follow, this fixed it permanently and it was a one time glitch (probably related to HA updates as I think the issue started with an combined update from core and supervisor), but I got a feeling in my gut that this is not the case, so watch out for further diagnostics.
funny thing is, all other mqtt commands where executed normally. only the tablets stopped responding to any mttq command sent, not just the speak via tts commands, they kept transmitting their status via mqtt how ever.
I also upgraded this morning, before I tried the reboot with the host, I think it was the supervisor to 22.3.5 but the restarts required with that update did not fix the tablet thing.
