[HELP] my web GUI constantly reconnecting whenever I use my FQDN
Hello Everyone,
I’m going crazy… every few minutes I’m getting the message of reconnecting to the web (“Connection lost. Reconnecting…”)
it only happens when I’m using the FQDN (my duckdns address). when using the IP address it works fine.
Did someone had/has this issue too??
(running all new versions up to date).
Regards,
Didi
Hey,
Did you figure this out ? I’m having the same issue. I suspect it’s to do with the websocket connection being cut by haproxy maybe, but it’s not clear in the network tab as it doesn’t look like the websocket ever really stops getting events.
Also the mobile app is fine, going through the same path, which doesn’t really make sense to me.
Sorry about the delay, I had no idea what fixed it… the problem disappeared after few restarts.
