I need a little advice please.
I have 2 MQTT switches I am trying to configure.
The command which needs to be sent needs to be sent in base64, however I need to declare a port on which to communicate in addition to the payload.
The format needs to be as follows:
The default topic for scheduling downlink payloads is:
application/APPLICATION_ID/device/DEV_EUI/command/down
The Application ID and DevEUI of the device will be taken from the topic.
Example payload:
"devEui": "1234567890123456",
"confirmed": false,
"fPort": 85,
"data": "CAAA/w=="
Can I use this in a template in the payload on and payload off?
Many thanks
