Hi all,
I found a minor inconsistency with the Fritzbox integration when creating a scene that is supposed to set a group of thermostats to certain temperatures.
I am not sure if this is HA core or anything else and how exactly to create an issue (although I am familiar with github and I am an active contributor to multiple open source projects). The link “not sure where to go” or similar leads to Discord - where I did not get any reaction since Friday.
So I am posting again on this platform. Hope this is OK.
My posting on Discord:
----------- snip -----------
difficult to describe. The thermostat has got a setting that goes up to 28 Celsius. And the HA UI won’t let me save a scene defining a higher value. So far so reasonable.
But it looks like there is one additional step internally coded as 30 Celsius for which the e-ink display on the device then shows “MAX”. And whenever I try to save a scene with 28 Celsius it somehow magically jumps to 30/MAX and I get the error that 30 is out of bounds.
When I edit the YAML back to 28 the scene works fine. The dashboard widget for the thermostat shows 30, though.
So there’s some inconsistency here.
Why do I need this? In our appartment all the heaters share a single pipe and if I do not crank the small one in the bath room to “MAX”, the other rooms stay cold. So that’s that
Help appreciated - unsure how to file a proper bug report. Is this HA core? Or something different? If I am not mistaken one could simply raise the limit for that thermostat to 30 C and be done with it?
So how do I go about getting somebody’s attention?
Thanks and best regards,
Patrick
