Help needed: Debug automation
Hi!
How can I debug my automation?
I’ve set logging defaut to debug but nothing shows up in the log if for example a trigger matches or only one of two conditions. How to debug my automation if the automation doesn’t fire?
Thanks in advanced :slight_smile:
If you remove the qualifier from logging (i.e. just have logger: by itself), you should see everything. Logs get pretty big after a while so you may want to switch back once you finish debugging.
Hm that didn’t work out for me :confused:
tried to set it to default notset, debug and info and removed the logger completely.
I can see a lot of debug messages but none of them affect automation or trigger.
Currently I'm trying to debug this automation task:
    - alias: Turn on light on sunset
        - platform: sun
          event: sunset
          offset: '+00:00:00'
      condition:
        - condition: state
          entity_id: group.all_devices
          state: 'home'
        - condition: state
          entity_id: input_boolean.light_sunset
          state: 'on'
       -  service: light.turn_on
          entity_id: light.wz, light.az
            profile: relax
            transition: 600
It's not fireing and I don't know why exactly.
states are as follows:
on	friendly_name: Switch on light at sunset
icon: mdi:weather-sunset
group.all_deviceshomeauto: true
entity_id: device_tracker.hensingx220,device_tracker.xenia,device_tracker.hensing_nexus5x,device_tracker.geierandroid
friendly_name: all devices
hidden: true
order: 0
group.all_devices:
homeauto: true
hidden: true
order: 0
