I would like to automate my PWM controlled charger as follows
(Setup is ready, everything is running so far)
I have created two sensors from my Shelly 3EM to separate the following:
Power_Import =Import from Grid
Power_Export = Exporting Power to the Grid
Dimmer = Dimmer for Charger (600W)
I would like to have the following:
“If Power_Export >50Watt increase the dimmer by 5%, then if Power_Export still above 50Watt increase further by 5% to maximum power”
“If Power Export <50 go back 5%”.
“If Power_Import >10Watt turn off dimmer”.
Entities:
- sensor.power_import
- sensor.power_export
- light-esp8266_dimmer
Can someone help me with this, as I am not so fit in the automations.
