Greetings everyone
I’m rather new to HA so I apologize in advance for properly making all the rookie mistakes and not reading the most importen thread in this forum
I also hope that all the snippets are formatet correctly. At least I tried.
My setup:
RPI 3 B+
Nortek Linear HUSBZB-1 Z-wave + ZigBee dongle
Ikea Tradfri GU10 LED bulb (brand new and never paired with other gateways)
Installed Hassbian and running HA v0.84.6
The ZigBee part of the HUSBZB-1 is giving me a hard time!
HA says that the zha (zigbee) device is configured but when I call the zha.permit service and turn on the Ikea bulb like described by @jfox here: Has anyone tried the Sengled LED bulb with the HUSBZB-1?
absolutely nothing happens.
lsusb on the RPI shows this:
pi@hassbian:~ $ lsusb
Bus 001 Device 004: ID 10c4:8a2a Cygnal Integrated Products, Inc.
Bus 001 Device 005: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I’ve check the HUSBZB-1 in my MacBook and it’s ID 10c4:8a2a so it’s been detected by the OS
It also show up in the /dev folder:
pi@hassbian:~ $ ls -l /dev/ttyU*
crw-rw---- 1 root dialout 188, 0 Dec 30 16:19 /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 1 Dec 30 17:36 /dev/ttyUSB1
I have added the following to the configuration.yaml:
zwave:
usb_path: /dev/ttyUSB0
zha:
usb_path: /dev/ttyUSB1
database_path: /home/homeassistant/.homeassistant/zigbee.db
In the home-assistant.log there is no errors and the zigbee.db file was created.
Under Setting - Integrations both the Z-Wave and the ZHA device is showen and on the States page in HA the Z-wave device is also shown. Not the ZHA but then again I don’t know if the ZHA device should be shown in the States page or only the paired devices (if you have any)!?
At the moment I don’t have any Z-wave devices so I can’t test that part of the HUSBZB-1.
Are there any other log-files that I can check for errors or info? Will the result of call service zha.permit be written to a log-file?
Is there a way to manually test the HUSBZB-1 device? Either on the RPI or on a computer?
In another thread in this forum I saw @winter writing something about a patch he had to install but also that it should be included in Bellows by now. I can’t find anything about this anywhere else. Anybody got a clue about this?
Am I missing something obvious to get this to work or what?
By the way, I bought 2 HUSBZB-1 brand new and they behave the same way so I don’t think it’s a hardware problem.
Regards
John
