I’ve been working on this issue the whole day but still can’t figure it out.
My HA is installed within DSM7 via docker.
I am getting 400 Bad Request when accessing the HA domain after setting up Cloudflare following this vid “https://www.youtube.com/watch?v=xXAwT9N-7Hw&t=546s” and also using this add-on “https://github.com/brenner-tobias/addon-cloudflared/blob/a3ad8795c5799570b556b5f381ed7c3c924448b2/cloudflared/DOCS.md”
Inside the add-on
and I can see the log successful to connected
[01:32:10] INFO: Finished setting up the Cloudflare Tunnel
[01:32:10] INFO: Connecting Cloudflare Tunnel...
and inside configuration.yaml I added all cloudflare ip range (IP Ranges) alongside my docker ip following this (Home assistant (400 Bad Request) Docker + Proxy - Solution)
added the ip from HA log
The IP from docker
but still getting 400 Bad Request
Here’s my configuration.yaml
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
- 103.21.244.0/22
- 103.22.200.0/22
- 103.31.4.0/22
- 104.16.0.0/13
- 104.24.0.0/14
- 108.162.192.0/18
- 131.0.72.0/22
- 141.101.64.0/18
- 162.158.0.0/15
- 172.64.0.0/13
- 173.245.48.0/20
- 188.114.96.0/20
- 190.93.240.0/20
- 197.234.240.0/22
- 198.41.128.0/17
- 170.30.32.2
- 172.30.33.1
- 172.17.0.0/16
- 172.30.32.0/23
- 172.30.32.1
- 172.18.0.0/16
- 172.18.0.1
- 172.18.0.2/16
- 172.30.32.0/23
- 127.0.0.1
- 10.0.0.2
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
Am I missing something or anything else I could try?
Thanks in advance
