Hi all,
I’ve been trying for the past day trying to figure out what happened and how to fix it:
I realised yesterday both my Home Assistant instances stopped connecting to GitHub for updates (through the Git Pull add-on) around the same time, 2 weeks ago. I saw it when I saw in the logs that Git Pull couldn’t connect and then on GitHub, the key they were using said was used last time 2 weeks ago.
This happened on both instances I have (they connect to different repos on the same account), one is a RPi and the other is a Mac mini running HA on a VM. The RPi instance was seeded from a backup from the one running on the Mac mini. Git Pull was working on both in the beginning of March. I also usually keep my machines up-to-date, so consider they were being updated as soon as updates were available.
I started to try and fix it and generated new keys but now the Git Pull add-on logs show
Check SSH connection
[Warn] No valid SSH connection for [email protected]
[Info] Start adding SSH key
[Info] Setup deployment_key on id_rsa
/run.sh: line 35: /.ssh/id_rsa: No such file or directory
chmod: /.ssh/config: No such file or directory
chmod: /.ssh/id_rsa: No such file or directory
[Info] Local git repository exists
[Info] Git origin is correctly set to [email protected]:(...).git
[Info] Start git fetch...
[email protected]: Permission denied (publickey).
fatal: Could not read from remote repository.
[Error] Git fetch failed
Please make sure you have the correct access rights
and the repository exists.
This log is also strange because the add-on creates the /.ssh/
repo itself and creates the config
file. Why does it fail to find the file afterwards?
If I connect through SSH to Home Assistant I can connect to GitHub and do git pull
. This is using the new key I generated when trying to solve the Git Pull issue.
Can anyone help? I didn’t find anyone with a similar issue in my searches on Google.
I’m wondering if something changed recently in how add-ons communicate with the rest of the file system that could explain this.
