Help Needed: GLEDOPTO Pro+ 5 in 1 LED Controller and Adaptive Lighting Integration
Hi everyone,
I have several GLEDOPTO Pro+ 5 in 1 LED controllers, which are recognized as GL-C-008P in zigbee2mqtt. These controllers have a local push button switch for manual control, and I’ve managed to get them to report their state back to Home Assistant when the button is pressed.
The issue I’m facing is with the Adaptive Lighting addon. Adaptive Lighting works perfectly when I turn on the lights via Home Assistant, but it doesn’t activate when I use the local push button on the LED controller.
Has anyone successfully integrated these LED controllers with Adaptive Lighting so that it activates whether the lights are turned on via Home Assistant or the local push button? Any guidance or tips on how to achieve this would be greatly appreciated!
Thanks in advance for your help!
