Help needed - Home Assistant restart automatically
Hi there,
I have a big problem with my Home Assistant. I have a Synology NAS and I’m running Home Assistant as Virtual Machine. Everything works fine and I did not change anything yesterday but since this night home assistant gui wasn’t reachable. Now its the following state:
  • I can boot the system without errors. But after loading all integrations home assistant core suddenly restarts.
  • I installed a fresh new vm and restored the backup from yesterday and the day before. Same result.
  • I deactived all addins and deactived, they should boot at startup. Result is still the same.
  • Reboot in safe-mode worked once a time but when I try it via the CLI i still get this error:
So I don’t know what to do now in troubleshooting. Has anybod a hint for me to search for? May it be one Integration, wich stops the whole core-service? But there was no update for one yesterday…
I’m not a homeassistant expert - so I kindly ask for help…
Best regards
David
Does HA restart or does VM restart?
There is no error that will cause HA to reboot on its own. It either encounters error and restarts or host system crashes causing restart.
Solved it - the integration Stiebel Eltron makes the problem in the actual version. So after rolling back to the old version HA starts without a problem. Thank you.
