Hi all. I have a project in mind, but I have not really an idea on where to start to implement it…
I have a smart thermostat, a way to monitor my ftv production and both configured in HA. What I would like to do is to command my heat pump based on my ftv production, ie like this (times and temperatures are as an example):
- between 18.30 and 0.00, heater off;
- between 0.00 and 4.30 heater at 18.5°;
- between 4.30 and 10.00 heater at 19.5°;
- between 10. 00 and 18.30 heater at 20.5°
(and this is easy )
But if between 4.30 e le 18.30 the ftv production is over a certain point set the temperature at 22° instead of the one on program… Also, make the check only at certain intervals, in order to avoid continuous on and off of the heat pump…
I think it would be not so difficult to implement after understand how, but I cannot figure out a simple way to do it, except to use an automation with a lot of conditions and cases…
Any advice?
Thanks!
