I got a robovac Dreame S7 setup in HA and it works perfectly. Via automation I can get it to clean a specific room and make it go back to the dock earlier.
I also want to start the vac by voice via Google Home. For this I added an input_button to HA and to the automation. In HA-Google Assistant I added an alias for this button. If I use this alias in a voice command then I am able to start the vac. All good this far.
The robovac can also be directed to a specific room to clean. I used the same routine here and setup a input_button and automation. Added the entity to Google Assistant, gave it an alias and made it available. But now I ran into a problem.
I want to let the robovac clean the kitchen (keuken in Dutch). Kitchen is also a area name.
remark: Stofzuig = Vacuum clean
As alias I use [Stofzuig de keuken] but this confused Google Home
Is there a better way to start an automation via Google Home?
