Hi. I made this blueprint based on a working automation, but I am getting error when I try to use it.
blueprint:
name: Humidity Activated HVAC
description: Turn an air condition on in dry mode based on the humidity level
domain: automation
input:
humidity_state_sensor:
name: "Humidity State Sensor"
description: "Must output 3 values: low, medium or high."
selector:
entity:
domain: sensor
condition_binary_sensor:
name: "Binary Sensor for Condition"
description: "Binary sensor that decides if the automation should be activated."
selector:
entity:
domain: binary_sensor
name: "Air Conditioner"
description: "Select a HVAC unit or a room."
selector:
device:
integration: daikin
mode: single
- platform: state
entity_id: !input humidity_state_sensor
to: "high"
condition:
- condition: state
entity_id: !input condition_binary_sensor
- service: climate.set_hvac_mode
hvac_mode: dry
target: !input target
- wait_for_trigger:
- platform: state
to: "low"
hvac_mode: 'off'
And the errors are:
Blueprint Humidity Activated HVAC generated invalid automation with inputs OrderedDict([('hvac', '6ed56c92d5ff970692a6a710ed032d8f'), ('condition_binary_sensor', 'binary_sensor.home_occupancy'), ('humidity_state_sensor', 'sensor.guest_room_humidity_state')]): required key not provided @ data['condition'][0]['state']. Got None
Blueprint Humidity Activated HVAC generated invalid automation with inputs OrderedDict([('humidity_state_sensor', 'sensor.guest_room_humidity_state'), ('condition_binary_sensor', 'binary_sensor.home_occupancy'), ('hvac', 'climate.guest_room')]): expected a dictionary for dictionary value @ data['action'][0]['target']. Got None required key not provided @ data['condition'][0]['state']. Got None
Blueprint Humidity Activated HVAC generated invalid automation with inputs OrderedDict([('humidity_state_sensor', 'sensor.guest_room_humidity_state'), ('condition_binary_sensor', 'binary_sensor.home_occupancy'), ('hvac', '6ed56c92d5ff970692a6a710ed032d8f')]): expected a dictionary for dictionary value @ data['action'][0]['target']. Got None required key not provided @ data['condition'][0]['state']. Got None
Blueprint Humidity Activated HVAC generated invalid automation with inputs OrderedDict([('hvac', '6ed56c92d5ff970692a6a710ed032d8f'), ('condition_binary_sensor', 'binary_sensor.home_occupancy'), ('humidity_state_sensor', 'sensor.guest_room_humidity_state')]): expected a dictionary for dictionary value @ data['action'][0]['target']. Got None required key not provided @ data['condition'][0]['state']. Got None
Blueprint Humidity Activated HVAC generated invalid automation with inputs OrderedDict([('target', OrderedDict([('device_id', '6ed56c92d5ff970692a6a710ed032d8f')])), ('condition_binary_sensor', 'binary_sensor.home_occupancy'), ('humidity_state_sensor', 'sensor.guest_room_humidity_state')]): required key not provided @ data['condition'][0]['state']. Got None
