Hi, I have a NUC8 with Home Assistant OS running on it which I want to convert to passive cooling, I have found a nice matching 3D case design for it, but it has an Apple logo on it , can someone replace it with the Home Assistant ‘tree’ logo for me?
I have tried so many STL editors, but the online versions have a MB cap per STL file, and the case is 100MB+ and the offline versions have a steep learning curve.
If someone could recommend an STL editor and clear steps to get it replaced, I will give it another go (tried FreeCAD, MeshLab, amoung others online, and now stranded with Fusion 360 personal edition)
Have you tried the 3D Builder app thats included with Windows 10? I find that to be pretty easy to use, and you should be able to relatively easy accomplish what you want to do
