Dear all,
I Try to start and stop an addon of kodi but did not really understand how to od that.
#The first question would be:
How to find out the id of the addon
How to "translate this command into hass command?
"description": "Enables/Disables a specific addon",
"permission": "ManageAddon",
"type": "method",
"params": [
"type": "string",
"name": "addonid",
"required": true
"$ref": "Global.Toggle",
"name": "enabled",
"required": true
"returns": {
"type": "string"
Thanks for your help
this is my config:
transmission_stop:
alias: Stop Transmission
sequence:
- service: kodi.call_method
entity_id: media_player.kodi
method: Addons.SetAddonEnabled
addonid: service.transmission
params:
enabled: false
and this is my error
2020-03-01 15:10:30 ERROR (MainThread) [homeassistant.components.kodi.media_player] Run API method media_player.kodi.Addons.SetAddonEnabled({'addonid': 'service.transmission', 'params': OrderedDict([('addonid', 'service.transmission'), ('enabled', False)])}) error: {'code': -32602, 'data': {'method': 'Addons.SetAddonEnabled', 'stack': {'message': 'Missing parameter', 'name': 'enabled', 'type': ['string', 'boolean']}}, 'message': 'Invalid params.'}
tom_l
March 1, 2020, 2:24pm
3
Look at the URL in a web browser when you are viewing the Supervisor / Kodi addon page. The random alphanumeric part is the ID.
E.g. in this case: https://my_domain.duckdns.org/hassio/addon/15ef4d2f_esphome
15ef4d2f_esphome is the ID.
Thanks for the hint but I cannot watch service addons in the browser. You mean well the webinterface right? like IP:8080 ?
We completley misunderstand each other. I don’t have kodi addon for hassio but mean the transmission addon for kodi wanna control this addon via kodi platfomr and call_method
tom_l
March 1, 2020, 2:30pm
6
Oh a Kodi addon. No a home assistant addon. Got it. No idea sorry.
tom_l
March 1, 2020, 2:36pm
8
No idea about the ID but there’s some info in this thread about converting the Kodi API services to HA services for remote control that may help:
I give up. This curl command used to work:
'curl -u "kodi:mypwd" --header "Content-Type: application/json" --data "{\"jsonrpc\":\"2.0\",\"id\":1,\"method\":\"Player.SetSpeed\",\"params\":{\"playerid\":1,\"speed\":\"increment\"}}" "http://10.1.1.14:8080/jsonrpc"'
So I tried:
lounge_kodi_player_fast_fwd:
sequence:
- service: media_player.kodi_call_method
entity_id: media_player.lounge_osmc_kodi
method: Player.SetSpeed
playerid: 1
speed: Incremen…
Actually go to the thread and read the replies.
FransO
March 9, 2020, 9:08am
9
I’m using a mini media player to control my Kodi installation. I can start a Kodi addon. Stopping is more complex. You can switch to the menu or another addon but have to stop any mediaplayer that is started by the addon separately.
This is my Kodi remote in Home Assistant:
The four buttons on the right start Kodi addons. The only problem I have now is that the i-radio addon will not start. it generates an invalid params error. When I launch Chrome, I still have to switch to my KDE app to control it as Chrome runs outside of Kodi. I’m still looking for a way to control Chrome on the media player (an Ubuntu box) from HA. Below is the Yaml for the remote. The volume is controlled by an ampifier which, being twenty years old, can only be controlled by IR signals.
entity: media_player.kodi
hide:
controls: true
icon_state: false
mute: true
power_state: false
volume: true
idle_view:
when_idle: false
when_paused: false
when_standby: false
icon: 'mdi:kodi'
shortcuts:
buttons:
- data:
method: Input.Home
icon: 'mdi:home'
type: service
- data:
method: GUI.ActivateWindow
window: favourites
icon: 'mdi:star'
type: service
- data:
method: Input.Up
icon: 'mdi:arrow-up-bold'
type: service
- data:
method: Input.Back
type: service
- data:
addonid: plugin.audio.i-radio
method: Addons.ExecuteAddon
type: service
- data:
window: videos
type: service
- data:
method: Input.Left
icon: 'mdi:arrow-left-bold'
type: service
- data:
method: Input.Select
type: service
- data:
method: Input.Right
icon: 'mdi:arrow-right-bold'
type: service
- data:
addonid: plugin.video.youtube
params:
command: activate
type: service
- data:
window: music
type: service
- data:
method: Input.Info
icon: 'mdi:information'
type: service
- data:
method: Input.Down
icon: 'mdi:arrow-down-bold'
type: service
- data:
method: Input.ContextMenu
icon: 'mdi:menu-open'
type: service
- data:
addonid: plugin.audio.rco
type: service
- data:
method: Player.GoTo
playerid: 1
to: previous
icon: 'mdi:skip-backward'
type: service
- data:
method: Player.PlayPause
playerid: 1
icon: 'mdi:play-pause'
type: service
- data:
method: Player.Stop
playerid: 1
icon: 'mdi:stop'
type: service
- data:
method: Player.GoTo
playerid: 1
to: next
icon: 'mdi:skip-forward'
type: service
- data:
addonid: plugin.program.chrome.launcher
params:
command: activate
type: service
- data:
d: denon
f: vol_down
icon: 'mdi:volume-minus'
type: service
- data:
d: denon
f: mute
icon: 'mdi:volume-off'
type: service
- data:
d: denon
f: vol_up
icon: 'mdi:volume-plus'
type: service
- data:
method: System.EjectOpticalDrive
icon: 'mdi:eject'
type: service
- data:
d: denon
f: source
icon: 'mdi:exit-to-app'
type: service
columns: 5
type: 'custom:mini-media-player'
volume_stateless: true
FransO
March 9, 2020, 7:42pm
10
Forgot to mention that you can find the Kodi addonid in the .kodi/addon/addonname /addon.xml file in the home folder of the user that started Kodi. That is for Ubuntu. Don’t know where that file is on other platforms.
Thanks I created she’ll command switches now . I’ll post it later
my setup is KODI with a screen saver running with my pictures of the family, now I have surveillance cameras these I have integrated via script in Kodi which displays a small picture of the camera for 30 seconds, so far so good. but the script does not turn off the screen saver and thus I see
the picture of the surveillance camera not! in FHEM I had solved this quite simply with an exec mousemove, in Home Assistant this is certainly also possible unfortunately I do not yet understand how my approach
entity_id: media_player.kodi_b
method: Input.mousemove
but unfortunately it does not work has one an idea would be great!
IF someone has the same problem, it works with the command
method: Input.ExecuteAction
action: mousemove
