Help needed on how to install a custom card
I’ve added the file ‘thermostat-card.js’ into folder ‘/config/www’
I’ve added this to ui-lovelace.yaml
resources:
  - url: /config/www/thermostat-card.js?v=1
    type: module
name: My Awesome Home
  - title: Home
    cards:
      - type: custom:thermostat-card
        title: Thermostat
        entity: climate.ecobee
I’ve added this code to a manual card:
type: 'custom:thermostat-card'
and I get error
Custom element doesn’t exist: thermostat-card.
type: ‘custom:thermostat-card’
Where have I gone wrong?
The URL doesn’t include /config/www. replace /config/www/ with /local/
Thanks, but I still get the same error.
resources:
  - url: /local/thermostat-card.js?v=1
    type: module
  - title: Home
    cards:
        title: Thermostat
Is this the card you’re trying to use?
And you dropped the thermostat-card.js directly in www? You also need the lib js file as well.
Not sure, man. seems to me it’s just not loading the module. Perhaps it is incompatible? Looks like the last update to that card was over a year ago?
Maybe a weird question, but did you try to restart hass completely? It helped me a couple of times when I just had installed a new custom card
Yes, I tried a reboot. I’ve given up with custom cards now. Maybe sometime in the future there will be an easier way of installing them in HA.
