Help needed to get this tiny screen working - ESP32-c6 1.47in display
I’m trying to make the ESPHome initialization via the serial port of an ESP32C6.
https://web.esphome.io/
When I attempt to use the “Prepare for First Use” button on the main web page a box reports:
Error: Unsupported platform ESP32C6.
Only …S2, …S3, …C3 are supported.
How were you able to upload to ESP32C6?
My thanks
Taken from discord group. Only issue is it sets the flash as 8MB instead of 4MB but it seems to work. Having issues with the screen but everything else is working
esphome:
friendly_name: esp32c6new
platformio_options:
platform: https://github.com/platformio/platform-espressif32/archive/refs/tags/v6.7.0.zip
board_build.f_cpu: 160000000L
board_build.f_flash: 80000000L
board_build.flash_size: 4MB
build_flags: “-DBOARD_HAS_PSRAM”
board_build.arduino.memory_type: qio_opi
esp32:
board: esp32-c6-devkitm-1
variant: esp32c6
framework:
type: esp-idf
version: 5.2.1
platform_version: 6.7.0
# version: latest
sdkconfig_options:
CONFIG_ESPTOOLPY_FLASHSIZE_4MB: y
Dont want to read the long text ?
Scroll down to EDIT 2 :wink:
I am also trying to get this little screen in esphome
but after successful connection it stuck on the “circle of dead” with “Preparing Installation”
grafik
  • Mac Mini M4 with Mac OS 15.3
  • Chrome Version 133.0.6943.54 (Offizieller Build) (arm64)
  • Connected via Nabu Casa (https)
  • CP210x and CH34x Driver are installed (both, to make sure)
    grafik
  • entered boot mode by holding the boot button while powering up (screen is black instead of showing the demo)
I already tried to uninstall and reinstall esphome
I tried this config:
esphome:
  platformio_options:
esp32:
  variant: esp32c6
  framework:
    type: esp-idf
    version: 5.2.1
    # version: latest
    sdkconfig_options:
and also this config: (found on the esp github page)
esphome:
  platformio_options:
    build_flags: "-DI2C_NUM_1=I2C_NUM_0"
esp32:
  board: esp32-c6-devkitc-1
  # flash_size: 4MB
  variant: esp32c6
  framework:
    type: esp-idf
    version: "5.3.1"
    platform_version: 6.9.0
Any ideas ?
EDIT:
After some time (for the 1st code block) I got this message:
grafik
If I click on “See what went wrong”
I get this log:
EDIT 2:
With this code
esphome:
esp32:
  variant: esp32c6
  framework:
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESPTOOLPY_FLASHSIZE_8MB: y
    version: 5.1.2
    platform_version: 6.5.0
    source: https://github.com/tasmota/esp-idf/releases/download/v5.1.2.240221/esp-idf-v5.1.2.zip
I was able to compile. It was complaining about the 8MB size but its working.
with
spi:
  clk_pin: GPIO7
  mosi_pin: GPIO6
display:
  - platform: st7789v
    model: CUSTOM
    dc_pin: GPIO15
    height: 320
    width: 172
    offset_height: 34
    offset_width: 0
    cs_pin: GPIO14
    reset_pin: GPIO21
    backlight_pin: GPIO22
    spi_mode: 3
    data_rate: 4000000.0
    lambda: |-
      // Draw a circle in the middle of the display
      it.filled_circle(it.get_width() / 2, it.get_height() / 2, 20);
its drawing the circle in the middle of the screen.
Thanks to all contributors.
It does work now. Took hours but the code below works!
For beginners like me - First time install:
Write the yaml file and then complile manually to make a download bin file.
Plug the ESP32C6-lcd into your PC - check there’s a COM port has come up.
Now, using Chrome on Esphome Web connect and download the bin file to the COM port.
It should reboot and show some text!
After first file write then you can upload wirelessly on subsequent ones if you’ve set wifi correctly and esphome can find it.
I had issues with an error coming up that there was a lock file for a long time.
I had to delete the original file, paste the yaml into a new one and then manually connect again.
The next long waste of time was the unit needs to be ‘added in’ the esphome integration to be able to send data from homeassistant to it. Otherwise the sensor info comes up as nan.
p.s. Remember to ask an AI because they seem to be good at finding some useful hints.
esphome:
  friendly_name: Esp32-LCD
esp32:
  variant: esp32c6
  framework:
    type: esp-idf
    version: 5.1.2
    sdkconfig_options:
wifi:
  ssid: !secret wifi_ssid
# snip - other parts in here to deal with fonts, colours, sensors etc taken from homeassistant to display on the screen.
# It didn't need another 'backlight' setting statement. Data rate doesn't seem to matter if 4000000 or 5000000
spi:
  clk_pin: GPIO7
  mosi_pin: GPIO6
display:
  - platform: st7789v
    model: Waveshare 1.47in 172X320
    dc_pin: GPIO15
    cs_pin: GPIO14
    reset_pin: GPIO21
    spi_mode: 3
    data_rate: 5000000.0
    update_interval: 1s
    rotation: 270
    lambda: |-
      it.rectangle(0,  0, it.get_width(), it.get_height(), id(my_blue));
      it.rectangle(0, 28, it.get_width(), it.get_height(), id(my_blue));   // header bar
      it.strftime(15, 2, id(helvetica_24), id(my_gray), TextAlign::LEFT, "%Y-%m-%d", id(esptime).now());
      it.strftime(160, 2, id(helvetica_24), id(my_gray), TextAlign::LEFT, "%H:%M:%S", id(esptime).now());
      it.print(10, 35, id(helvetica_24), id(my_red), "Electrical Power");
      it.printf(10, 65, id(arial), id(my_gray), "G1:%.0fW G1k:%.0fW G1w:%.0fW", id(g1_power).state, id(g1k_power).state, id(g1w_power).state);
      it.printf(10, 85, id(arial), id(my_gray), "G2:%.0fW G2f:%.0fW G2ts:%.0fW", id(g2_power).state, id(g2f_power).state, id(g2ts_power).state);
You’re going to have to define the sensors and colours and time output but they should be fairly easy. Sample here:
time:
  - platform: homeassistant
    entity_id: sensor.g1_c0_main_power_minute_average
# these bits below don't seem to matter if in or not
    unit_of_measurement: "W"
    state_class: "measurement"
    internal: true
Here’s my config that reports the wifi signal, home assistant API connection and the temperature and humidity index from my Bambu Lab AMS.
Feel free to change the font files for your own liking.
My working config:
substitutions:
  friendly_name: "ESP32-C6-LCD-1.47"
  device_name: esp32-c6-lcd-147
  area: Home Assistant
  device_description: ""
  bt_proxy: "false"
  logger: "DEBUG"
  # logger: "VERY_VERBOSE"
  vendor: "Waveshare"
  model: "ESP32-C6-LCD-1-47in"
  device_version: "v"
  microcontroller: "ESP32-C6FH4 (QFN32) (revision v0.1)"
  frequency: "160MHz"
  ram: "512KB"
  rom: "320KB"
  hp_sram: "512KB"
  lp_sram: "16KB"
  flash: "4MB"
  features: "WiFi 6, BT 5, Thread (802.15.4)"
  crystal: "40MHz"
  mac: "9c:9e:6e:ff:fe:76:51:a8"
  base_mac: "9c:9e:6e:76:51:a8"
  mac_ext: "ff:fe"
  # i2c
  i2c_id: bus_a
  sda: GPIO1
  scl: GPIO2
  scan: "false"
  # SPI bus for LCD and SD Card
  miso_pin: GPIO5
  mosi_pin: GPIO6
  clk_pin: GPIO7
  # LCD Pinout
  lcd_cs_pin: GPIO14
  lcd_dc_pin: GPIO15
  lcd_reset_pin: GPIO21
  lcd_backlight_pin: GPIO22
  # SD Card
  sd_cs_pin: GPIO4
  # LED
  rgb_led: GPIO8
  # One Wire
  one_wire: GPIO10
i2c:
  - id: $i2c_id
    sda: $sda
    scl: $scl
    scan: False
spi:
  clk_pin: $clk_pin
  miso_pin: $miso_pin
  mosi_pin: $mosi_pin
one_wire:
  - pin: $one_wire
    platform: gpio
esp32:
  variant: esp32c6
  flash_size: 4MB
  framework:
    type: esp-idf
    version: 5.3.1
    sdkconfig_options:
      CONFIG_ESPTOOLPY_FLASHSIZE_DETECT: y
      CONFIG_OPENTHREAD_ENABLED: n
      CONFIG_USE_MINIMAL_MDNS: y
      # Memory optimization
      COMPILER_OPTIMIZATION_SIZE: y
      COMPILER_OPTIMIZATION_LEVEL_RELEASE: y
      CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_DISABLE: y
      CONFIG_HEAP_POISONING_DISABLED: y
esphome:
  friendly_name: $friendly_name
  name_add_mac_suffix: false
  comment: "${device_description}"
  area: $area
  project:
    version: "${device_version}"
  platformio_options:
    board_build.flash_mode: dio
    build_flags:
      - "-DI2C_NUM_1=I2C_NUM_0"
      - "-DBOARD_HAS_PSRAM"
      - "-Wl,-Map,output.map"
    platform_packages:
      - platformio/toolchain-xtensa-esp-elf @ 14.2.0+20241119
logger:
  level: $logger
api:
  reboot_timeout: 300s
  on_client_connected:
    if:
      condition:
        api.connected:
      then:
        - logger.log:
            format: "API Connection: %s [%s]"
            args: ["client_info.c_str()", "client_address.c_str()"]
  on_client_disconnected:
    - logger.log:
        format: "API Disonnection: %s [%s]"
ota:
  - platform: esphome
safe_mode:
  on_safe_mode:
    - logger.log: "Safe Mode Activated"
wifi:
  fast_connect: off
  reboot_timeout: 5min
  power_save_mode: HIGH
  # ap:
  #   ssid: "${friendly_name} Fallback"
  #   password: !secret wifi_ap_password
  #   manual_ip:
  #     static_ip: $static_ip
  #     gateway: !secret gateway
  #     subnet: !secret subnet
  #     dns1: !secret dns1
  #     dns2: !secret dns2
  #   ap_timeout: 5min
  on_connect:
    then:
      - logger.log: "WiFi connected"
  on_disconnect:
    then:
      - logger.log: "WiFi disconnected"
  # ESP-IDF ONLY https://esphome.io/components/wifi.html
  # Enable 802.11v BSS Transition Management support.
  enable_btm: true
  # Enable 802.11k Radio Resource Management support.
  enable_rrm: true
network:
  enable_ipv6: False
# https://esphome.io/components/esp32_ble_tracker
# Enable Bluetooth Proxying
esp32_ble_tracker:
  scan_parameters:
    interval: 1100ms
    window: 1100ms
    active: ${bt_proxy}
    continuous: false
  on_scan_end:
    - then:
        - lambda: |-
             ESP_LOGD("ble_auto", "The scan has ended!");
# https://esphome.io/components/bluetooth_proxy.html
bluetooth_proxy:
  # Enables proxying active connections. Defaults to false.
  active: ${bt_proxy}
  cache_services: true
# https://esphome.io/components/esp32_improv.html
esp32_improv:
  authorizer: none
  on_start:
    then:
      - logger.log: "Improv awaiting authorization/authorized"
  on_provisioning:
    then:
      - logger.log: "Improv provisioning"
  on_provisioned:
    then:
      - logger.log: "Improv provisioned"
  on_stop:
    then:
      - logger.log: "Improv stopped"
  on_state:
    then:
      - if:
          condition:
            lambda: return state == improv::STATE_AUTHORIZED;
          then:
            - logger.log: "Improv state is STATE_AUTHORIZED"
# https://esphome.io/components/improv_serial
improv_serial:
# https://esphome.io/components/captive_portal
# captive_portal:
# deep_sleep:
#   run_duration: 2min   # Time the device stays awake
#   sleep_duration: 28min  # Time the device sleeps
text_sensor:
  # ESPHome Version
  - platform: version
    icon: si:esphomes
    hide_timestamp: 'true'
    entity_category: diagnostic
  # WiFi Info: IP, MAC, SSID, BSSID, Scan
  - platform: wifi_info
    ip_address:
      icon: mdi:ip
      update_interval: never
      disabled_by_default: True
    mac_address:
      name: "WiFi MAC Address"
      icon: mdi:fingerprint
    ssid:
      icon: mdi:wifi-settings
    bssid:
      icon: mdi:wifi
    scan_results:
      name: "Latest Scan Results"
      icon: mdi:wifi-sync
binary_sensor:
  # https://esphome.io/components/binary_sensor/status.html
  # Reports if this device is Connected or not
  - platform: status
    icon: mdi:check-network
button:
  # Remotely reboot your node into Safe Mode.
  # https://esphome.io/components/switch/safe_mode.html
  - platform: safe_mode
    icon: mdi:restart-alert
    entity_category: config
  # Restart
  - platform: restart
    icon: mdi:restart
    # entity_category: diagnostic
  # Shutdown
  - platform: shutdown
light:
  # RGB LED
  - platform: esp32_rmt_led_strip
    pin:
      number: $rgb_led
      ignore_strapping_warning: true
    chipset: ws2812
    rmt_channel: 0
    num_leds: 1
    rgb_order: RGB
    # gamma_correct: 2.8
    default_transition_length: 2s
    restore_mode: RESTORE_DEFAULT_OFF
    effects:
      - random:
      - random:
          name: "My Slow Random Effect"
          transition_length: 30s
          update_interval: 30s
      - random:
          name: "My Fast Random Effect"
          transition_length: 4s
          update_interval: 5s
      - pulse:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
          min_brightness: 0%
          max_brightness: 100%
      - pulse:
          transition_length: 500ms
          update_interval: 2s
      - pulse:
          name: "Asymmetrical Pulse on1s off500ms"
          transition_length:
            on_length: 1s
            off_length: 500ms
          update_interval: 1.5s
      - strobe:
      - strobe:
          name: "Strobe Effect br100 r100g90b0 250/500"
          colors:
            - state: true
              brightness: 100%
              red: 100%
              green: 90%
              blue: 0%
              duration: 500ms
            - state: false
              duration: 250ms
            - state: true
              brightness: 100%
              red: 0%
              green: 100%
              blue: 0%
              duration: 500ms
      - flicker:
      - flicker:
          name: "Flicker a95 i1.5"
          alpha: 95%
          intensity: 1.5%
      - addressable_rainbow:
          width: 12
          name: "Rainbow sp10 w50"
          speed: 10
          width: 50
      - addressable_color_wipe:
          name: "Color Wipe r100g100b100 100ms"
          colors:
            - red: 100%
              green: 100%
              blue: 100%
              num_leds: 1
              gradient: true
            - red: 0%
              green: 0%
              blue: 0%
              num_leds: 1
          add_led_interval: 100ms
          reverse: false
      - addressable_scan:
      - addressable_scan:
          name: "Scan Effect i100ms w1"
          move_interval: 100ms
          scan_width: 1
      - addressable_twinkle:
          name: "Twinkle p5 i4ms"
          twinkle_probability: 5%
          progress_interval: 4ms #default 4ms
          name: "Twinkle p50 i4ms"
          twinkle_probability: 50%
      - addressable_random_twinkle:
          name: "Random Twinkle p50 i32ms"
          progress_interval: 32ms
      - addressable_fireworks:
          name: "Fireworks sp10% fade120 i32ms"
          spark_probability: 10%
          use_random_color: false
          fade_out_rate: 120
          update_interval: 32ms
      - addressable_flicker:
          name: Flicker Effect With Custom Values
          update_interval: 16ms
          intensity: 5%
      - addressable_lambda:
          update_interval: 10ms
          lambda: |-
            static uint8_t brightness_step = 0;
            static bool brightness_decreasing = true;
            static uint8_t brightness_step_number = 10;
            if (initial_run) {
            Color error_color(255, 0, 0);
            for (int i = 0; i < 12; i++) {
              it[i] = error_color * uint8_t(255/brightness_step_number*(brightness_step_number-brightness_step));
            if (brightness_decreasing) {
              brightness_step++;
            } else {
              brightness_step--;
            if (brightness_step == 0 || brightness_step == brightness_step_number) {
              brightness_decreasing = !brightness_decreasing;
# Sync time with Home Assistant.
time:
  - platform: uptime
    type: timestamp
  # WiFi Signal sensor
  - platform: wifi_signal
    icon: mdi:wifi-strength-outline
  - platform: copy
    source_id: wifi_signal_db
    name: "WiFi Signal Percent"
    unit_of_measurement: "%"
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    entity_category: "diagnostic"
    device_class: ""
  - platform: uptime
    type: seconds
  - platform: internal_temperature
    name: "Internal Temperature"
    entity_id: sensor.ams_temperature
    internal: true
    unit_of_measurement: "°F"
    entity_id: sensor.ams_humidity_index
    internal: true
font:
  - file: "common/fonts/8-bit-nintendo.ttf"
    size: 7 # Pixel Perfect
  # - file: "common/fonts/8-bit-nintendo.ttf"
  #   id: nes_3x
  #   size: 21
  #   id: nes_4x
  #   size: 28
  # - file: "common/fonts/gotham-Light-webfont.ttf"
  #   id: gotham_lt
  #   size: 25
  - file: "common/fonts/gotham-Medium-webfont.ttf"
  # - file: "common/fonts/gotham-Black-webfont.ttf"
  #   id: gotham_b
  #   size: 30
image:
    # Home Assistant Logo
  - file: mdi:home-assistant
    # resize: 35x35
    resize: 150x150
    # WiFi
  - file: mdi:signal-cellular-3
    # resize: 35x35
  - file: mdi:signal-cellular-2
    # resize: 35x35
  - file: mdi:signal-cellular-1
    # resize: 35x35
  - file: mdi:signal-cellular-outline
    # resize: 35x35
  - file: mdi:signal-off
    resize: 150x150
    # Temperature
  - file: mdi:thermometer-low
    resize: 200x200
    resize: 200x200
  - file: mdi:thermometer-high
    resize: 200x200
    # Humidity
  - file: mdi:water
    resize: 100x100
  # - file: mdi:water-percent
  #   id: hum_icon
  #   resize: 30x30
  # - file: mdi:water-percent-alert
  #   id: hum_icon_alert
  #   resize: 30x30
output:
  - platform: ledc
    pin: $lcd_backlight_pin
    frequency: 1000 Hz
number:
    name: "Display Brightness"
    optimistic: true
    min_value: 0
    max_value: 100
    step: 1
    initial_value: 100
    restore_value: true
    mode: slider
    on_value:
      then:
        - output.set_level:
            level: !lambda "return x / 100.0;"
# https://esphome.io/components/display/
# TFT Display (ST7789)
display:
  - platform: st7789v
    cs_pin: $lcd_cs_pin
    dc_pin:
      number: $lcd_dc_pin
    reset_pin: $lcd_reset_pin
    rotation: 0
    lambda: |-
      ESP_LOGD("display", "Display update running");
      auto black = Color(0, 0, 0);
      auto gray = Color(128, 128, 128);
      auto red = Color(255, 0, 0);
      auto orange = Color(255, 165, 0);
      auto yellow = Color(255, 255, 0);
      auto green = Color(0, 255, 0);
      auto blue = Color(0, 0, 255);
      auto hablue = Color(3, 169, 244);
      auto white = Color(255, 255, 255);
      // Check if the HA time text sensor is available
      // if (id(readable_ha_time).has_state() && id(readable_ha_time).state.length() > 0) {
        // Print time from HA text sensor
      //   it.printf(it.get_width()/2, 10, id(nes_1x), TextAlign::TOP_CENTER, "%s", id(readable_ha_time).state.c_str());
      // } else {
        // Fallback to time from ESPHome's `homeassistant_time`
        auto cur_time = id(homeassistant_time).now();
        if (cur_time.is_valid()) {
          auto hour = cur_time.hour;
          auto ampm = "am";
          // Convert military time to standard AM/PM format
          if (hour > 12) hour = hour - 12;
          if (hour >= 12) ampm = "pm";
          if (hour == 0) hour = 12; // Midnight adjustment
          // Print formatted time
          // it.printf(it.get_width()/2, -10, id(nes_2x), TextAlign::TOP_CENTER, "%2d:%02d %s", hour, cur_time.minute, ampm);
          it.printf(it.get_width()/2, -8, id(nes_2x), TextAlign::TOP_CENTER, "%2d:%02d", hour, cur_time.minute);
        } else {}
      // Determine the appropriate WiFi icon
      if (!id(wifi_signal_percent).has_state()) {
        // Display WiFi off icon when disconnected
        it.image(it.get_width()/2, it.get_height()/2, id(wifi_off), ImageAlign::CENTER, gray);
      } else {
        // Home Assistant API Connection Status
        if (!id(api_id).is_connected()) {
          // When disconnected, draw the icon with reduced opacity or you could skip drawing it
          it.image(it.get_width()/2, it.get_height()/2, id(home_assistant_logo_l), ImageAlign::CENTER, gray); // Gray color for disconnected state
        } else {
          it.image(it.get_width()-2, 0, id(home_assistant_logo), ImageAlign::TOP_RIGHT, hablue);
        // WiFi Signal Strength Status
        int wifi_strength = id(wifi_signal_percent).state;
        if (wifi_strength >= 75) {
          it.image(5, 0, id(wifi_3), ImageAlign::TOP_LEFT, green);
        } else if (wifi_strength >= 50) {
          it.image(5, 0, id(wifi_2), ImageAlign::TOP_LEFT, orange);
        } else if (wifi_strength >= 25) {
          it.image(5, 0, id(wifi_1), ImageAlign::TOP_LEFT, yellow);
        } else {
          it.image(5, 0, id(wifi_0), ImageAlign::TOP_LEFT, red);
      // Humidity Index
      if (id(ams_humidity_index).has_state()) {
        if (!isnan(id(ams_humidity_index).state)) {
          //Humidity Index Status
          int hum_idx = id(ams_humidity_index).state;
          if (hum_idx == 1) {
            it.image(it.get_width()/2 +10, it.get_height()/2, id(temp_low), ImageAlign::CENTER, blue);
            it.image(it.get_width()/2 -38, it.get_height()/2 +2, id(water_drop), ImageAlign::CENTER, black);
            it.image(it.get_width()/2 -40, it.get_height()/2, id(water_drop), ImageAlign::CENTER, blue);
          } else if (hum_idx == 2) {
            it.image(it.get_width()/2 +10, it.get_height()/2, id(temp_med), ImageAlign::CENTER, green);
            it.image(it.get_width()/2 -40, it.get_height()/2, id(water_drop), ImageAlign::CENTER, green);
          } else if (hum_idx == 3) {
            it.image(it.get_width()/2 +10, it.get_height()/2, id(temp_med), ImageAlign::CENTER, yellow);
            it.image(it.get_width()/2 -40, it.get_height()/2, id(water_drop), ImageAlign::CENTER, yellow);
          } else if (hum_idx == 4) {
            it.image(it.get_width()/2 +10, it.get_height()/2, id(temp_high), ImageAlign::CENTER, orange);
            it.image(it.get_width()/2 -40, it.get_height()/2, id(water_drop), ImageAlign::CENTER, orange);
          } else if (hum_idx == 5) {
            it.image(it.get_width()/2 +10, it.get_height()/2, id(temp_high), ImageAlign::CENTER, red);
            it.image(it.get_width()/2 -40, it.get_height()/2, id(water_drop), ImageAlign::CENTER, red);
          } else {}
          it.printf(it.get_width()/2 +10, it.get_height()/2 +40, id(gotham_md), white, TextAlign::CENTER, "%.0f", id(ams_humidity_index).state);
        } else {}
      } else {}
      // AMS Temperature
      if (id(ams_temperature).has_state()) {
        if (!isnan(id(ams_temperature).state)) {
          it.printf(it.get_width()/2, it.get_height()+10, id(nes_2x), white, TextAlign::BOTTOM_CENTER, "%.0f °F", id(ams_temperature).state);
        } else {}
      } else {}
I can’t compile it, i always get error messages. can you share the already compiled bin file?
Thanks, this works perfectly! Also, I must say it’s a very nice layout.
Before I found your config, I struggled quite a while with the display working initially but not after a restart. I wonder what exactly in your config solved this. Is it due to the newer ESP-IDF?
PS: Check out Time Component — ESPHome strftime. You could use something like it.strftime(it.get_width()/2, 2, id(nes_2x), TextAlign::TOP_CENTER, "%I:%M", cur_time); to display the time in the imperial 12-hour format and save a few lines of code.
Make sure to update to the latest ESPHome device builder. If it still doesn’t work, post the error messages here.
Surely you will want to adapt the config somewhat, so a .bin file won’t be very helpful.
Thanks! Although I am certainly not a coder, I do have a design background. I wish I could figure out how to use gradients but I’m always hitting the 4MB limit of storage on this little guy.
I struggled with getting this device to work. I scoured through github and these were the latest settings I could find that would compile (challenge no. 1), boot (challenge no. 2) and not crash (challenge no. 3, aka the final boss).
Thank you for the suggestion of the time component. I’ll integrate that into my collection of snippets I use across my esphome projects.
Ultimately though… I’m still in my return window and am gonna send this back. I found the amount of storage too limiting and I’d rather learn how to use LVGL and no matter what settings/optimizations/component removals I tried, I just couldn’t get LVGL to fit in the storage amount and work. I think the best I got was 100.63% of the storage size. I’m gonna go with the gambler’s take on this one…
“Gotta know when to hold 'em, know then to fold 'em.”
Godspeed to the rest of ya.
I’ve set spi_mode to 0, and solved it for me… :slight_smile:
i’ve also set height and width
spi_mode: 0
height: 320
width: 172
# esphome heart rate monitor based on Waveshare ESP32C6 LCD 1.47 (https://www.waveshare.com/wiki/ESP32-C6-LCD-1.47)
# the code is taken from here with my corrections https://community.home-assistant.io/t/help-needed-to-get-this-tiny-screen-working-esp32-c6-1-47in-display/800102/30
# enter esphome api key and ble_mac of your HRM monitor device
# also change your home assistant temperature sensor entity_id to get it on the screen
# time is 24h formatted
# you can also change color of current heart rate for your specific needs...
substitutions:
  friendly_name: "esp32c6-lcd"
  device_name: esp32c6-lcd
  logger: "DEBUG"
  ble_mac: ***
  vendor: "Waveshare"
  device_version: "v"
  frequency: "160MHz"
  ram: "512KB"
  rom: "320KB"
  hp_sram: "512KB"
  lp_sram: "16KB"
  flash: "4MB"
  crystal: "40MHz"
  # i2c
  i2c_id: bus_a
  sda: GPIO1
  scl: GPIO2
  scan: "false"
  miso_pin: GPIO5
  mosi_pin: GPIO6
  clk_pin: GPIO7
  # LCD Pinout
  lcd_cs_pin: GPIO14
  lcd_dc_pin: GPIO15
  # SD Card
  sd_cs_pin: GPIO4
  # LED
  rgb_led: GPIO8
  # One Wire
  one_wire: GPIO10
i2c:
  - id: $i2c_id
    sda: $sda
    scl: $scl
    scan: False
spi:
  clk_pin: $clk_pin
  miso_pin: $miso_pin
  mosi_pin: $mosi_pin
one_wire:
  - pin: $one_wire
    platform: gpio
esp32:
  variant: esp32c6
  flash_size: 4MB
  framework:
    type: esp-idf
    version: 5.3.1
    #version: 5.4.0
    #platform_version: 6.10.0
    sdkconfig_options:
esphome:
  area: $area
  project:
  platformio_options:
    build_flags:
    platform_packages:
logger:
  level: $logger
api:
  encryption:
    key: "***"
ota:
  - platform: esphome
    password: "***"
wifi:
  fast_connect: off
  #power_save_mode: HIGH
  ap:
    ssid: "Esp32C6-Lcd Fallback Hotspot"
    password: "***"
ble_client:
  - mac_address: "${ble_mac}"
binary_sensor:
  - platform: status
button:
  # Restart
  - platform: restart
    icon: mdi:restart
  # Shutdown
time:
  - platform: uptime
    type: timestamp
    entity_id: sensor.xiaomi_4_temperatura
    internal: true
    #unit_of_measurement: "°C"
  - platform: ble_client
    type: characteristic
    ble_client_id: heart_rate_monitor
    name: "${device_name} Heart rate measurement"
    service_uuid: '180d'  # Heart Rate Service
    characteristic_uuid: '2a37' # Heart Rate Measurement
    notify: true
    lambda: |-
      uint16_t heart_rate_measurement = x[1];
      if (x[0] & 1) {
          heart_rate_measurement += (x[2] << 8);
      return (float)heart_rate_measurement;
    icon: 'mdi:heart'
    unit_of_measurement: 'bpm'
    update_interval: 1s
font:
  #- file: "common/fonts/gotham-medium.ttf"
  #   id: nes_3x
  #   size: 21
  #   id: nes_4x
  #   size: 28
  #   id: gotham_lt
  #   size: 25
  #   id: gotham_b
  #   size: 30
output:
  - platform: ledc
    frequency: 1000 Hz
number:
    optimistic: true
    min_value: 0
    max_value: 100
    step: 1
    initial_value: 100
    restore_value: true
    mode: slider
    on_value:
      then:
        - output.set_level:
display:
  - platform: st7789v
    cs_pin: $lcd_cs_pin
    dc_pin:
      number: $lcd_dc_pin
    #rotation: 0
    rotation: 270
    lambda: |-
      // } else {
          //auto ampm = "am";
          //if (hour > 12) hour = hour - 12;
          //if (hour >= 12) ampm = "pm";
          //if (hour == 0) hour = 12; // Midnight adjustment
          //it.printf(it.get_width()/2, -8, id(nes_2x), TextAlign::TOP_CENTER, "%2d:%02d", hour, cur_time.minute);
          it.printf(it.get_width()*2/3, +8, id(nes_2x), white, TextAlign::CENTER, "%2d:%02d", hour, cur_time.minute);
        } else {}
            // AMS Temperature
          //it.printf(it.get_width()/2, it.get_height()+10, id(nes_2x), white, TextAlign::BOTTOM_CENTER, "%.0f °C", id(ams_temperature).state);
          it.printf(it.get_width()/3, +8, id(nes_2x), white, TextAlign::CENTER, "%.0f °C", id(ams_temperature).state);
        } else {}
      } else {}
      // heart_rate_measurement
      if (id(heart_rate_measurement).has_state()) {
        if (!isnan(id(heart_rate_measurement).state)) {
          //it.printf(it.get_width()/2 +10, it.get_height()/2 +40, id(gotham_md), white, TextAlign::CENTER, "%.0f", id(heart_rate_measurement).state);
          int hrm_rate = id(heart_rate_measurement).state;
          if (hrm_rate > 90) {
            it.printf(it.get_width()/2, it.get_height()/2 +15, id(gotham_md), red, TextAlign::CENTER, "%.0f", id(heart_rate_measurement).state);
          else {
            it.printf(it.get_width()/2, it.get_height()/2 +15, id(gotham_md), white, TextAlign::CENTER, "%.0f", id(heart_rate_measurement).state);
        } else {}
      } else {}
It can be compiled in esphome 2025.2.2 without nasty “Error: The program size (XXXXX bytes) is greater than maximum allowed (1835008 bytes)” cos I deleted extra stuff.
I’ve made some changes to get a heart rate monitor that gets data from BLE HRM device (e.g. Fitcent CL820W or any Polar tracker)
Thanks for everyone sharing. I did a speculative buy on the Waveshare ESP32-S3 LCD7.5in and ESP32-C6 LCD 1.45"
I’m new to HA, though have long term experience with embeddedC++ and a fan of microPython when possible.
For new frameworks I try a basic configuration and then let it run for a couple of days to see how stable it is.
HA is fantastic for that User Interface of stepping to a webserver. Wow.!
I purloined a basic Clock program using the ESP32-S3 7.5in working of a rPi5 server. Been well behaved for a week now. Gets time and all the buttons work.
I’m so appreciative of the ESP32-C6 discussion here, but its been a lot longer trying to get it working. I wanted to be able to Totalize pulses coming from my house water meter - prototyped with touching a pin to gnd with a 0.1uF debounce capacitor and R.The ping GPIO0 is pulled up internally.
The basics of the display works nicely. Though I’ve a few other problems - getting the time from the HA doesn’t work it has the default 1970. Measuring and printing pulses is not accurate. .
So it maybe that its some HA framework issues as it’s not officially supported, or more likely something I have missed. Putting out my yaml, and open to any suggestions what I might be doing wrong. Thanks for any thoughts
What it looks like running, step into it and there is time lapse, https://photos.app.goo.gl/4odbHZx4dme9rFKB7
# 250416 sensor_pulse_C6_LCD_1-5in
# Measuring 1 pulse ports, changing LED colour based on speed, and reporting results
# Using a wavershare ESP32-C6 with LCD 1.47"
# ESP32-C6FH4 = processors 32bit RISC (LP @20Mhz + 160MHz)
# sram(HP 512KB of LP 16KB), flash4MBy
# LCD 172×320 resolution, 262K color
# RGB LED - WS2812B-0807   GPIO8
# TF card slot - faces into board, not easyly removed
substitutions:
  friendly_name: "esp32c6new-AC"
  device_name: esp32c6new-ac
  logger_dbg: "DEBUG"
  # logger_dbg: "VERY_VERBOSE"
  # ble_mac: ***
  #vendor: "Waveshare"
  #model: "ESP32-C6-LCD-1-47in"
  #device_version: "v"
  #microcontroller: "ESP32-C6FH4 (QFN32) (revision v0.1)"
  #frequency: "160MHz"
  #ram: "512KB"
  #rom: "320KB"
  #hp_sram: "512KB"
  #lp_sram: "16KB"
  #flash: "4MB"
  #features: "WiFi 6, BT 5, Thread (802.15.4)"
  #crystal: "40MHz"
  input_pulse1 : GPIO0
  input_pulse2 : GPIO1
  input_pulse3 : GPIO2
  input_pulse4 : GPIO3
  # https://community.home-assistant.io/t/help-needed-to-get-this-tiny-screen-working-esp32-c6-1-47in-display/800102/32
  # i2c
  i2c_id: bus_a
  #i2c_sda: GPIO1
  #i2c_scl: GPIO2
  #i2c_scan: "false"
  spi_miso_pin: GPIO5
  spi_mosi_pin: GPIO6
  spi_clk_pin: GPIO7
  # LCD Pinout
  lcd_cs_pin: GPIO14
  lcd_dc_pin: GPIO15
  # SD Card
  sd_cs_pin: GPIO4
  # LED
  rgb_led: GPIO8
  # One Wire
  one_wire: GPIO10
esphome:
  friendly_name: esp32c6new_AA
esp32:
  variant: esp32c6
  framework:
    type: esp-idf
    sdkconfig_options:
logger:
  level: $logger_dbg
  logs:
    component: ERROR
# Enable Home Assistant API
api:
  encryption:
    key: ".."
  actions:
  - action: set_total
    variables:
      new_total: int
    then:
      - pulse_meter.set_total_pulses:
          value: !lambda 'return new_total;'
ota:
  - platform: esphome
    password: ".."
wifi:
  ap:
    ssid: "Esp32C6New-Ab Fallback Hotspot"
    password: "XItuOVn1aIXN"
captive_portal:
spi:
  clk_pin: $spi_clk_pin
  mosi_pin: $spi_mosi_pin
  #miso_pin: $spi_miso_pin
binary_sensor:
  #- platform: status
  #  name: "Status"
  #  id: "${id}_status"
  #  icon: mdi:check-network
button:
  # Restart
  - platform: restart
    icon: mdi:restart
  # Shutdown
time:
    on_time:
      - seconds: "*"
        then:
          - script.execute: clock_update
text_sensor:  #shows on web page
    lambda: |-
      char formatted_time[30];  // 16chars Space for "YYYY:MM:DD HH:MM\0"
      snprintf(formatted_time, sizeof(formatted_time), "%02d-%02d-%02d %02d:%02d", id(esptime).now().year,id(esptime).now().month, id(esptime).now().day_of_month, id(esptime).now().hour, id(esptime).now().minute);
      ESP_LOGD("HA_time", "update time %s", formatted_time);
      return esphome::optional<std::string>(formatted_time);
  - platform: uptime
    type: seconds
    update_interval: 60s
  # Pulse count
  # https://esphome.io/components/sensor/pulse_counter
  #- platform: pulse_counter
  #  name: "Pulse Rate Count1"
  #  id: pulse_count1
    #internal: true
  #  internal_filter: 13us #max for EPS32 13us
  #  accuracy_decimals: 0
    #update_interval: 10s
    #unit_of_measurement: "pulse/min"
  #  pin: # with pullup
  #    number: $input_pulse1
  #    inverted: true
  #    mode:
  #      input: true
  #      pullup: true
  #  total:
  #    name: "Pulse Total Count1"
  #    id: pulse_tot_count1
#https://esphome.io/components/sensor/pulse_meter.html
  - platform: pulse_meter
    #internal: true
    pin: # with pullup
      inverted: true
      mode:
        input: true
        pullup: true
    total:
font:
  #- file: "fonts/arial.ttf"
  #  id: arial_98
  #  size: 98
  - file: "fonts/PIXY.ttf"
script:
  - id: clock_update
    then:
      #current_time = id(esptime)
      # end
output:
  - platform: ledc
    frequency: 1000 Hz
number:
    optimistic: true
    min_value: 0
    max_value: 100
    step: 1
    initial_value: 100
    restore_value: true
    mode: slider
    on_value:
      then:
        - output.set_level:
display:
  - platform: st7789v  # https://esphome.io/components/display/st7789v
    model: CUSTOM
    # says driver st7789v superseded, but couldn't make this work
    #- platform: ili9xxx  # https://esphome.io/components/display/ili9xxx
    #  model: st7789v
    #  invert_colors: true
    #Reference is USB-C at bottom width/narrow x height/tall
    # chip supports 240x320, LCD is 172x320
    width: 172
    height: 320
    offset_height: 34 #34 #offset LCD is smaller than the maximum supported by the driver chip.
    offset_width: 0
    #dimensions: # ili9xxx , confused with offset or
    #  width: 172
    #  height: 320
      #offset_height: 0 #34 #offset LCD is smaller than the maximum supported by the driver chip.
      #offset_width: 78
    rotation: 270
    dc_pin: $lcd_dc_pin
    cs_pin: $lcd_cs_pin
    spi_mode: 0
    update_interval: 1s
    # auto_clear_enabled: false.
    lambda: |-
      // auto gray = Color(128, 128, 128);
      // auto red = Color(255, 0, 0);
      // auto orange = Color(255, 165, 0);
      // auto yellow = Color(255, 255, 0);
      // auto green = Color(0, 255, 0);
      // auto blue = Color(0, 0, 255);
      // auto hablue = Color(3, 169, 244);
      static int  test_pass_cnt = 0;
      test_pass_cnt = test_pass_cnt +1;
      ESP_LOGD("display", "Display update running %d", test_pass_cnt);
      if ( (int)0x01 & test_pass_cnt) {
        it.strftime(it.get_width()/10, it.get_height()/10, id(nes_2x), "%Y-%m-%d %H:%M", id(esptime).now());
      } else {
        // Draw ref the middle display for reference
        if ( 1) { //id(pulse_count1).has_state()  && id(pulse_tot_count1).has_state() ) {
          int hght =it.get_height()/4;
          it.printf(0, hght , id(nes_2x), TextAlign::TOP_LEFT ,"Pulse1 Cnt ");
          it.printf(0, hght+20 ,id(nes_2x),TextAlign::TOP_LEFT,"%3d",(unsigned)id(pulse_count1).state);
          it.printf(0, hght+40 ,id(nes_2x),TextAlign::TOP_LEFT,"%3d",(unsigned)id(pulse_tot_count1).state );
*** Update: Solved see below ***
I bought one of these and have no luck with the display. I’ve tried a the last two configs posted above, adjusting I guess for esphome 2025.4, and taking out stuff I didn’t have connected and didn’t need to keep it from barfing on total size.
The device works in that it joins the network and I can see the logs, web browser works, and the LED light works, the screen backlight comes on and I can change its brightness, but I get nothing displayed, it’s just a flat grey (interestingly not black).
I see no apparent error (other than the display taking too long to appear).
I’m unsure where to start on debugging. I realize I haven’t given much to go on, but I don’t have much – can someone give me a feel for how to approach debugging the display?
The display did work with whatever firmware as on the device when I got it, so I do not think it is physically broken.
Those who had working configs above – does it still work with esphome 2025.4.0?
Update 4/26/2025: I figured this out, it’s a collection of bad choices I think. The compile objected to RGB24 on the image types (though it wasn’t there) and advice was to change it to RGB. So I put RGB on each image, and none of them worked (more precisely they all came out black or missing or something, no errors). In looking at other possibilities one was BINARY, I tried that and an image appeared. So none of the images that I was using to test worked. But now that I can see things I can get the rest to work.
The screen is blank after initial boot, then do a reset and all the graphics/text etc you have written pops up.
btw. Does anyone know how to get this to happen straight away without having to reset/restart from a button push?
Other OLED units come up but this unit does not display immediately after a power outage.
I’m not seeing that. Mine comes up pretty quick, takes a few seconds to join the wifi network but the screen is there. I just power cycled it to make sure.
Which config are you using?
Or do you have a more complicated script that check on start up?
This script seems to have broken with Esphome update.
it encounters a: ModuleNotFoundError: No module named ‘pkg_resources’:
when compiling.
Any ideas?
I did notice an option for selecting esp32c6 on the setup choices.
Got the same error, it’s due to framework/platform versions.
After fiddling around a bit, I got it working.
Here is my YAML, the only new thing I did is the RGB LED light control.
substitutions:
esp32:
  variant: esp32c6
  flash_size: 4MB
  framework:
    type: esp-idf
    version: 5.3.1
    sdkconfig_options:
esphome:
  friendly_name: "ESP32-C6 1.47 LCD"
  project:
    version: "v"
  platformio_options:
    build_flags:
    platform_packages:
logger:
# RGB LED
light:
    rgb_order: RGB
    pin: GPIO8
    num_leds: 1
    chipset: SK6812
api:
  encryption:
    key: "..."
ota:
  - platform: esphome
    password: "..."
wifi:
  use_address: 10.0.30.55
i2c:
  - id: bus_a
    sda: GPIO1
    scl: GPIO2
    scan: False
spi:
  clk_pin: GPIO7
  miso_pin: GPIO5
  mosi_pin: GPIO6
one_wire:
  - pin: GPIO10
    platform: gpio
binary_sensor:
  - platform: status
button:
  - platform: restart
    icon: mdi:restart
time:
  - platform: uptime
    type: timestamp
    entity_id: sensor.aqara_t_h_bureau_temperature
    entity_id: sensor.consommation_totale_bureau
    entity_id: sensor.ups_baie_puissance_reelle_actuelle
    entity_id: sensor.ups_pc_puissance_reelle_actuelle
output:
  - platform: ledc
    pin: GPIO22
    frequency: 1000 Hz
number:
    optimistic: true
    min_value: 0
    max_value: 100
    step: 1
    initial_value: 100
    restore_value: true
    mode: slider
    on_value:
      then:
        - output.set_level:
display:
  - platform: st7789v
    cs_pin: GPIO14
    dc_pin:
      number: GPIO15
    reset_pin: GPIO21
    rotation: 0
    lambda: |-
      auto color = Color(40, 140, 186);
      // Draw the background image
      it.image(0, 0, id(background));
      // Time
        it.printf((it.get_width()/2), +14, id(font20), color, TextAlign::CENTER, "%2d:%02d", hour, cur_time.minute);
      // Ups #1
      if (id(ups_baie_puissance_reelle_actuelle).has_state()) {
        if (!isnan(id(ups_baie_puissance_reelle_actuelle).state)) {
          it.printf((it.get_width()/2)-38, 57, id(font20), color, TextAlign::CENTER, "%.0fw", id(ups_baie_puissance_reelle_actuelle).state);
      // Ups #2
      if (id(ups_pc_puissance_reelle_actuelle).has_state()) {
        if (!isnan(id(ups_pc_puissance_reelle_actuelle).state)) {
          it.printf((it.get_width()/2)+38, 57, id(font20), color, TextAlign::CENTER, "%.0fw", id(ups_pc_puissance_reelle_actuelle).state);
      // Measurement
      if (id(bureau_temperature).has_state()) {
        if (!isnan(id(bureau_temperature).state)) {
          it.printf(it.get_width()/2, (it.get_height()/2)-8, id(font62), color, TextAlign::CENTER, "%.0f", id(bureau_conso).state);
      // Measurement
          it.printf(it.get_width()/2, (it.get_height()/2)+44, id(font22), color, TextAlign::CENTER, "WATTS");
      // Bottom Temperature
          it.printf(it.get_width()/2, it.get_height()-23, id(font20), color, TextAlign::CENTER, "%.1f °C", id(bureau_temperature).state);
font:
  - file: "gfonts://Orbitron"
image:
  - file: "images/1.47/background.png"
    type: rgb565
And here is the result :
Hope that helps !
Thank you, this got me started!!
thanks for sharing your yaml, saved me much frustration!
