Help needed to understand RF proxies: Why are no devices showing up?
I’ve built an esphome rf proxy and expected it to show all devices it can receive (and decode), but that doesn’t seem to be how it works.
I have a cheap 433 temperature sensor that is so old that I can’t even read the labels anymore, but it still sends data to it’s base station like a champ.
Is there a project or integration I need to add to show all devices it can receive and decode?
I’m using this code:
esphome:
  friendly_name: cc1101
# Replace this with your actual platform if you aren't using ESP32.
esp32:
  board: esp32dev
  flash_size: 4MB
  framework:
    type: esp-idf
    version: recommended
    sdkconfig_options:
      COMPILER_OPTIMIZATION_SIZE: y
      #CONFIG_FREERTOS_UNICORE: y
      #CONFIG_ESP32_DEFAULT_CPU_FREQ_160: y
      #CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ: "160"
      #CONFIG_ESP_TASK_WDT_TIMEOUT_S: "20"
      #CONFIG_BT_BLE_50_FEATURES_SUPPORTED: y
      #CONFIG_BT_BLE_42_FEATURES_SUPPORTED: y
  variant: ESP32
wifi:
  ssid: !secret wifi_nonet_ssid
  password: !secret wifi_nonet_password
  fast_connect: true #required for hidden ssids
  reboot_timeout: 10min
  #output_power: 8.5
logger:
  level: DEBUG
debug:
  update_interval: 5s
# Enable Home Assistant API
api:
  encryption:
    key: !secret ha_api_key
ota:
  - platform: esphome
    encryption:
time:
  - platform: homeassistant
esp32_ble_tracker:
  #max_connections: $max_ble_connections
  scan_parameters:
    #continuous: true
    interval: 211ms
    window: 120ms
bluetooth_proxy:
  #connection_slots: 5
  active: true
safe_mode:
spi:
  clk_pin:
    number: GPIO18
  miso_pin: GPIO19
  mosi_pin: GPIO23
cc1101:
  cs_pin: GPIO5
 # modulation_type: ASK/OOK
 # symbol_rate: 5000
 # filter_bandwidth: 200kHz
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: true
text_sensor:
  - platform: debug
    device:
    reset_reason:
#  - platform: ble_scanner
#    name: "BLE Devices Scanner"
  - platform: hdc1080
    temperature:
      name: CC1101 Temperature
      icon: "mdi:temperature-celsius"
    humidity:
      icon: "mdi:water-percent"
    update_interval: 60s
# CC1101 GDO0 wired to one GPIO pin
remote_transmitter:
  pin: GPIO4
  carrier_duty_percent: 100%
  on_transmit:
    then:
      - cc1101.begin_tx: cc1101_radio_433
  on_complete:
    then:
      - cc1101.begin_rx: cc1101_radio_433
# CC1101 GDO2 wired to a second GPIO pin
remote_receiver:
  pin: GPIO13
radio_frequency:
  - platform: ir_rf_proxy
    name: RF Proxy Transmitter
    frequency: 433.92MHz
    remote_transmitter_id: rf_tx_433
    # Optional: retune the CC1101 when an API request specifies a different
    # carrier frequency.  `x` is the radio_frequency call object.
    on_control:
      then:
        - if:
            condition:
              lambda: "return x.get_frequency().has_value() && *x.get_frequency() > 0;"
            then:
              - cc1101.set_frequency:
                  value: !lambda "return *x.get_frequency();"
    name: RF Proxy Receiver
    remote_receiver_id: rf_rx_433
