Help Needed: Unable to connect Leviton d215 switch via Matter
I am very confused about what I need to do to get the connection established and working.
Do I need to turn anything else on in Home Assistant other than enable the Matter integration?
Do I need to convert my ZBT-1 from Zigbee to be a thread router? or pick up the new skyconnect and have it be the thread router?
If I am doing Matter over wifi do I even need the openrouter integration?
What is prompting this is that I am wanting to migrate my Leviton D215 from plain wifi and the MyLeviton app to instead be connected to Home Assistant so that I can work it in to some routines.
I did the hold down for 14 seconds to rest to factory and then used the Matter pairing code string typed in to HA, that failed to create it.
So I wiped and redid it again and this time when adding it “saw” the switch as a named device (assuming this is picking up the broadcasting ID from the switch) but then it still fails to add.
I have confirmed I am on the same 2.4Ghz WiFi network and am not going out to Nabu Casa for anything.
Has anyone run in to this?
Suggestions on how to fix?
Thanks!
From what I can tell, this device is NOT a Matter device, so you won’t be able to use HA’s Matter setup for this.
Did you look at the following:
It can be Matter by updating the firmware on it.
Which is what I have done, and why the device shows up with the Matter pairing code.
Ah…ok…
So stepping through this, you used your HA Companion App to do the commissioning, and the HA Companion App indeed has to be on the same WiFi 2.4GHz network that is used to reach HA. The Companion App essentially is giving the Leviton device the WiFi credentials to join the WiFi network. So when you used the Companion App to “Matter Add Device”, you picked “new” (and not “existing”), and it usually asks to scan a QR code, or sounds like you skipped that part and entered the pairing code manually.
If this is what you have done and it failed, then 1) See if IPv6 is enabled in your HA UI->Settings->network, and if this is enabled, 2) check the Matter AddOn logs to see what it says.
I am having the same problem with the same switch. I can add this switch to Apple Home without any issue and control it. That to me confirms the swithc is good,m the switch is matter enabled and I have a thread network. My thread network is via an apple tv HD. I am pretty confident that the matter is configured as I have added a tapco device with matter and I added the Hue Hub with matter. I have reset the switch to default new mode. I also have a 2.4 wifi network with IPV6 enabled. I have searched and searched the docs trying to find what I am doing wrong as I hate posting a question to a thread that I should have found on my own. When I use the HA companion app on the phone all works to the point where you are supposed to scan the QR code. The camera comes up and that is where it stops. It will not scan the barcode. I also added a couple other switches that I was able to get the matter code from the Home Assitant app but not all devices show the prompt for putting the remote device into pairing mode. So it seems to be specific to the camera and it seems like there is a credential problem or it is simply not able to deal with the qr code on the Leviton Device I don’t know how that lookup occurrs.
With the help of Leviton Tech Support I was able to resolve this issue
Well, I fixed it! I sent a note to Leviton Tech support asking them why on my app it was not showing the matter code. The answer? Firmware was 1.6 instead of 2.5 These switches were brand new out of the box and yet the firmware was obsolete over two years ago. The app also has a funky way it works. It has an update function but all that does is go out and tag the devices that are out of date. You have to exit the app and then go back in and call up each device to select updating of that device. Of course it has to have a network connection to do that. So the result was you have to use the app to join it to the network and then use the network to get the update but you have to force each one individually. Once I did that the matter code showed up which I could then save on phone and print and then I was able to join it to Home Assistant and to Apple Home. They say that it can be tied to up to 5 controllers at a time. I would ask your advice if this is a good idea or not. Right now I have three of them tied to HA Homekit and the App and they all work and can be controlled on each app. I THOUGHT that if I added it to HA that it would come across the Homekit bridge integration and show up in apple. It would seem that if that would work it would be better than adding them to both. DO you have to do something to the bridge to get it to send across new devices that have been added to HA?
Leviton D215S switches
This procedure is for getting a Leviton switch connected via matter over wifi to Apple home and to Home Assistant as well as the Leviton app all simultaneously
It is not necessary to pull out the switch from the wall or remove the cover. If it is in pairing mode the app will find it via Blue Tooth
The first step is to make sure that the Leviton switch is on current firmware
Reset the switch to default by holding it on for at least 10 seconds until the light flashes amber and red
Make sure your phone is on a network that is broadcasting on 2.4 ghz and make sure that IPv6 is enabled
Using the Leviton app bring it near the switch and adopt the switch into the Leviton app. Give it a new name and room (create the room if not already there)
Once adopted use the leviton app to update the firmware to the latest version I had brand new off the shelf switches and they had two year old firmware. If your going to do matter over wifi the version has to be at least 2.??
Once updated the app will now show the matter code for the device. Save a screenshot to your phone, this captures the matter code and the name that it was given. Print this out so that it can be used to scan for adding the switch to other controllers.
Because of the reset if the device was in apple home it will be gone.
To add it back into apple home once again hold the switch in the on position but stop holding it as soon as it turns amber/red. If you hold it longer it will reset the switch and will not longer be on the wifi or tied to the Leviton app
The light will quickly change from amber to flashing green. At this point it still has the wifi but is in pairing mode.
Now add the device to apple home or to Home Assistant. For apple you can scan the QR code and it will adopt it into the Apple Home (I think that you have to have an apple TV or a Homepod on the network to provide the thread protocol long enough to join it, I am not positive of this but I had one on the network and this worked.
After it is adopted do the same procedure again putting it into pairing mode with the 7 second on press and add it to Home Assistant. Use the choice of the device being already adopted (not new) and then either scan the code or type it in. Side benefit of this is that you will have all the codes printed out and saved to your phone for future changes.
