Help Needed with Automation for Toggling Todo Status Based on NFC Tag Scan
Hello Home Assistant Community,
I’m new to Home Assistant and have been working on an automation to manage a “Restmüll” (waste) todo item using an NFC tag scan. My goal is to be able to scan the trash bin when it is full. Then a todo is beeing added to the wohnung_verlassen todo list. With another automation I read out all the open todos from this list when I leave the house. When I’ve emptied the trash, I want to re-scan the tag and set the todo back to completed. Despite several attempts, I keep running into issues, and I need your help to figure out what I’m doing wrong.
So what I’m Trying to Achieve:
  • Scan an NFC Tag: When I scan a specific NFC tag (ID: 20d0ad4f-7b0a-485c-881d-828bbdae4af8), it should:
    • Check if the “Restmüll” todo item exists in todo.wohnung_verlassen.
    • If it exists, toggle its status between needs_action and completed.
    • Send notifications about the actions taken.
What I’ve Tried
Here’s the current version of my automation:
alias: Restmüll Management
description: "Toggle Restmüll task based on NFC tag scan"
  - platform: tag
    tag_id: 20d0ad4f-7b0a-485c-881d-828bbdae4af8
condition: []
  - service: notify.mobile_app_pixel_5
      message: "NFC Tag scanned: {{ trigger.event.data.tag_id }}"
  - service: todo.get_items
      entity_id: todo.wohnung_verlassen
      status: needs_action
    response_variable: mylist
  - variables:
      restmuell_exists: "{{ 'Restmüll' in mylist['todo.wohnung_verlassen']['items'] | map(attribute='summary') | list }}"
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ restmuell_exists }}"
        sequence:
            response_variable: item_status
          - variables:
              current_status: "{{ item_status['todo.wohnung_verlassen']['items'] | selectattr('summary', 'eq', 'Restmüll') | map(attribute='status') | first }}"
          - choose:
              - conditions:
                    value_template: "{{ current_status == 'needs_action' }}"
                sequence:
                  - service: todo.update_item
                      item: Restmüll
                      status: completed
                      message: "Restmüll completed"
              - conditions:
                    value_template: "{{ current_status != 'needs_action' }}"
                sequence:
                      item: Restmüll
                      message: "Restmüll set to needs action"
      - conditions:
            value_template: "{{ not restmuell_exists }}"
        sequence:
          - service: todo.add_item
              summary: Restmüll
              message: "Restmüll item created and set to needs_action"
      message: "End of automation reached with tag: {{ trigger.event.data.tag_id }}"
mode: single
Issues I’m Facing:
Invalid Keys Error:
When trying to update the todo item, I receive the error: extra keys not allowed @ data[‘summary’].
Toggling Status:
Setting the status to completed works, but setting it back to needs_action doesn’t work, and I get the error: extra keys not allowed @ data[‘summary’].
What I’ve Tried
  • Ensuring that summary is only included when creating a new todo item.
  • Checking and updating the status based on conditions to toggle between needs_action and completed.
Can someone please help me understand why the todo.update_item service call is failing when I try to set the status to needs_action? Any guidance or suggestions on how to properly structure this automation would be greatly appreciated.
Thank you for your assistance!
I figured it out.
Here is a working automation, that can identify the current state of a todo.
description: Toggle Restmüll task based on NFC tag scan
  - platform: tag
condition: []
    data: {}  # Retrieve all items regardless of status
    response_variable: all_items
  - variables:
      current_status: >-
        {{ all_items['todo.wohnung_verlassen']['items'] |
        map(attribute='status') | first | default('not found') }}
  - choose:
      - conditions:
            value_template: "{{ current_status == 'completed' }}"
        sequence:
              item: Restmüll
              message: Restmüll bitte rausbringen
              title: Todo
                importance: high
      - conditions:
        sequence:
              item: Restmüll
              status: completed
              message: Restmüll erledigt
              title: Todo
                importance: high
    default:
          message: "Error: Unexpected status '{{ current_status }}' for Restmüll"
mode: single
