Thanks for the reply. However it doesn’t seem to work, always sends turn_off whether I set inside temp higher or lower then the outside temp. Perhaps the entire flow would be helpful? (Hope I sent the correct export data.) My original thinking was to have it trigger on either inside or outside temp, but it doesn’t make much difference it should get the job done either way.
FYI, I did try changing the upper case A in homeassistant to lower just to check. No difference. Also changed “on” and “off” to “turn_on” and “turn_off”.
[{"id":"4b836c9f.4c4014","type":"tab","label":"Upstairs Fan Control","disabled":false,"info":""},{"id":"d8929f1c.47bcb","type":"api-call-service","z":"4b836c9f.4c4014","name":"Fan On/Off","server":"dfc47a0d.c63b28","version":3,"debugenabled":false,"service_domain":"switch","service":"","entityId":"switch.02200194ecfabc869339","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":430,"y":140,"wires":[["ce89307e.751d1"]]},{"id":"ee00b5b7.a7d4d8","type":"server-state-changed","z":"4b836c9f.4c4014","name":"Outside Temp","server":"dfc47a0d.c63b28","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.dark_sky_temperature","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":70,"y":140,"wires":[["f7fae196.28993"]]},{"id":"15635c48.cd77d4","type":"server-state-changed","z":"4b836c9f.4c4014","name":"Inside Temp","server":"dfc47a0d.c63b28","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.inside_temperature","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":70,"y":80,"wires":[["f7fae196.28993"]]},{"id":"2989e9a6.ab71d6","type":"server-state-changed","z":"4b836c9f.4c4014","name":"Fan Control","server":"dfc47a0d.c63b28","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.fan","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":70,"y":200,"wires":[["5eec4101.df602","fe4f4af2.c7e618"]]},{"id":"f7fae196.28993","type":"function","z":"4b836c9f.4c4014","name":"","func":"if (msg.topic === \"sensor.dark_sky_temperature\") {\nvar outside=msg.payload;\n\n }\nif (msg.topic === \"sensor.inside_temperature\") {\nvar inside=msg.payload; \n }\nif (inside > outside) {msg.payload=\"turn_on\";\n}else {msg.payload=\"turn_off\";\n }\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":250,"y":80,"wires":[["d695d9f8.f16128","d9c052e1.d38d8"]]},{"id":"5eec4101.df602","type":"traffic","z":"4b836c9f.4c4014","name":"","property_allow":"payload","filter_allow":"on","ignore_case_allow":false,"negate_allow":false,"send_allow":false,"property_stop":"payload","filter_stop":"off","ignore_case_stop":false,"negate_stop":false,"send_stop":false,"default_start":false,"differ":false,"x":270,"y":140,"wires":[["d8929f1c.47bcb"]]},{"id":"d9c052e1.d38d8","type":"change","z":"4b836c9f.4c4014","name":"Payload.Service","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.service","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":80,"wires":[["5eec4101.df602"]]},{"id":"fe4f4af2.c7e618","type":"switch","z":"4b836c9f.4c4014","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":300,"y":200,"wires":[["3e89e432.cf55cc"]]},{"id":"3e89e432.cf55cc","type":"api-call-service","z":"4b836c9f.4c4014","name":"Fan Off","server":"dfc47a0d.c63b28","version":3,"debugenabled":false,"service_domain":"switch","service":"turn_off","entityId":"switch.02200194ecfabc869339","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":440,"y":200,"wires":[["da3964c4.c678f8"]]},{"id":"e1872c42.a23ea","type":"comment","z":"4b836c9f.4c4014","name":"Upstais Fan Control","info":"","x":90,"y":20,"wires":[]},{"id":"ce89307e.751d1","type":"debug","z":"4b836c9f.4c4014","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":590,"y":140,"wires":[]},{"id":"da3964c4.c678f8","type":"debug","z":"4b836c9f.4c4014","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":590,"y":200,"wires":[]},{"id":"d695d9f8.f16128","type":"debug","z":"4b836c9f.4c4014","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":410,"y":40,"wires":[]},{"id":"dfc47a0d.c63b28","type":"server","name":"Home Assistant-1","version":1,"legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
