Help needed with Gigaset Elements
I am very new to Home Assistant but managed to get basic integration of Hue and Synology Surveillance Station working. Now I want to integrate my existing Gigaset Elements System (a couple of door/window-, motion-sensors). I have found these two sites: https://github.com/dynasticorpheus/gigasetelements-cli and https://github.com/ycardon/gigaset-elements-proxy. But I have no clue to begin with, so I need help. Can someone provide me with step by step instructions?
Buck
Echoing this. Can anyone help with instructions?
Also interested in this.
I was able to install the the gigaset-elemts-proxy, but I still have problems with mqtt.
This is what I had to do (now I can see the incoming sensor data in the command line).
  • Installed Raspbian Stretch Lite on a Pi Zero W (SD Card 8GB)
  • Updated everything (use: “sudo apt-get update” and “sudo apt-get upgrade”)
  • Install git and npm (use: “sudo apt-get install git” and “sudo apt-get install npm”)
  • “git clone https://github.com/ycardon/gigaset-elements-proxy”
  • “cd gigaset-elements-proxy”
  • “npm install”
  • “sudo nano config/default.yaml” (did not know how to use vim)
  • edit this file to yours needs (login data from gigaset)
  • Press CTRL+X to save and close this file (Y to confirm)
  • “sudo apt-get install git”
After this I receive sensor data, but I don’t know where it publishes the mqtt data.
Unfortunately there is not documention about how or where to configurate the MQTT settings, like Server IP, user and password.
FYI, extra information about setting up can be found in the GitHub issue pages, many thanks to @h4nc for improving this project: https://github.com/ycardon/gigaset-elements-proxy/issues/1
I have a fresh installation of HassOS 3.11 on a rpi3.
Now, the installation of the addon fails with error log:
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] done.
[services.d] starting services
[services.d] done.
ifelse: fatal: unable to exec /run.sh: Exec format error
[cmd] /run.sh exited 126
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
How can I can fixed it?
@Buck_Rogers @psqv @Cavekeeper @h4nc
Just wanted to let you all know next to the cli I also have created a custom component which can easily be installed via HACS:
