Help needed with if elseif else statement formatting
Here’s the thing; I’d like to set light brightness based on time in an automation.
## Motion sensor wc
- alias: WC Lights off when motion off
    - platform: state
      entity_id: binary_sensor.wc_pir
      to: 'off'
      for:
        minutes: 8
    - service: light.turn_on
        entity_id: light.wc_ylavalo
        brightness: 0
- alias: WC Lights on when motion on
    - platform: state
      to: 'on'
  condition:
    condition: and
    conditions:
      - condition: template
        value_template: '{{ states.light.wc_ylavalo.attributes.brightness < 5 }}'
      - condition: numeric_state
        entity_id: sensor.wc_ldr
        below: 100
        brightness: >-
          {% if now().strftime('%H')| int >= 22 %}
            100
          {% elif now().strftime('%H')| int < 7 %}
            10
          {% elif now().strftime('%H')| int >= 7 %}
            255
          {% endif %}
I get the following error when triggering the automation above:
Invalid service data for light.turn_on: expected int for dictionary value @ data['brightness']. Got "{% if now().strftime('%H')| int >= 22 %}\n 100\n{% elif now().strftime('%H')| int < 7 %}\n 10\n{% elif now().strftime('%H')| int >= 7 %}\n 255\n{% endif %}"
The automation works fine without the if-elif-else block.
Any help is appreciated!
Br,
Mikko
Not sure, but i think you need data_template.
Thanks for your reply!
I’m not sure what you mean; data_template for what? Could you give me an example code?
Looking at the error message I think the interpreter does not recognise the if-else block at all and reads that as a string not as a peace of code…
Br,
Mikko
Sorry, sometimes i expect too much.
      data_template:
        brightness: >-
            100
            10
            255
          {% endif %}
With data the interpreter read every character ‘as is’, with data_template it renders the jinja in the template.
I think :grinning:
Thanks a lot! That did the trick! :slight_smile:
I’m not really ninja enough to master the jinja yet, it seems :smiley:
Seriously speaking, any pointers for a good cookbook to get on top of this stuff?
Br,
Mikko
Well like i said in my first reply, “Not sure”.
Sometimes it’s most trial and error and as time goes on, you get the ‘feeling’.
