Long story short, if a switch is “on” I want to to print “On” at row 1 column 18 on an LCD and if the switch is “off” I want to print “off” instead. Which sounds simple enough but I’m having hell’s own job formatting the lambda correctly.
Here is what I have…
switch:
- platform: gpio
pin: GPIO16
name: "Booth Fan Relay"
inverted: true
display:
- platform: lcd_pcf8574
dimensions: 20x4
address: 0x27
lambda: |-
it.print(0,0," Temp RH Fans" );
it.printf(0,1,"Now: %.1fc %.1f%%", id(booth_temp).state, id(booth_rh).state);
it.printf(0,2,"Min: %.1fc %.1f%%", id(min_temp).state, id(min_rh).state);
it.printf(0,3,"Max: %.1fc %.1f%%", id(max_temp).state, id(max_rh).state);
Looking at “states” in Home assistant, Booth Fan Relay is either “On” or “Off” but I guess it’s either true or false. So essentially if the state of (id) fan_relay is “on” then I want to show “On” at row 1, column 18 and if it’s “off” then I want to show “Off” at that position. I’ve tried every which way I can think of but not being a programmer, I haven’t managed to stumble across the correct way to do this. Any help you can give a 69 year old non-writer of code, would be much appreciated.
Edit. column 17, not 18
