Help needed with Rest Sensor parsing
I’m trying to integrate the local waste collection schedule into HA.
Found an API with all the dates, unfortunately, HA complains it’s too big (+255 chars) to import & template.
But with the help of Apify I managed to make the API response a lot smaller.
(Date fields are milisecond epoch)
But I still can’t manage to get it into HA…
Anyone able to help?
Sample API response:
      "Umido": "1539820800000",
      "Secco": "1540166400000",
      "Carta": "1539648000000",
      "Plastica": "1540339200000",
      "Vetro": "1539907200000",
      "Ecomobile": "1541462400000",
      "url": "http://www.convenzionerifiutisesto.it/RaccolteDomicilio/LoadRaccolteDomicilioForComune?comuneId=30"
Configuration Snippets:
Try 1:
    - platform: rest
      name: Umido Collection
      resource: https://api.apify.com/v1/wRi29ffoih2SPhwMA/crawlers/BC24cHRsNwCSM2epA/lastExec/results?simplified=1&token=worJhZpKAnHKCKv27dBsgkP5N
      value_template: '{{ (value_json.Umido | float / 1000) | timestamp_local }}'
Try 2:
      - platform: rest
        name: Waste Collection
        json_attributes:
          - Umido
Error log:
    2018-10-15 15:32:59 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: 'list object' has no attribute 'Umido' (value: [{
    }], template: {{ (value_json.Umido | float / 1000) | timestamp_local }})
Actually figured it out myself!
The API was returning a list to me, so the correct config is:
  - platform: rest
    value_template: '{{ (value_json[0].Umido | float / 1000) | timestamp_local }}'
Just trying to figure out now how to get the dates of all different waste collections in 1 API call rather than 6.
Normally, json_attributes parameter is what you need, but I understand that it only handles top level named elements, so I don’t think it will work with the json you currently get. If you can get rid of the array in the json using apify, you might be able to use it.
