Hi guys!
Quite new to Hass.io, I’m running into a brick wall with the problem below. I would appreciate any help or guidance!
I’m trying to group two IKEA Tradfri lights using the code below which is working great until i try to implement set_level.
The Tradfri lights only has the brightness attribute when they are “on”.
The new entity id “light.hallway” has no brightness attribute, even though “light.panel_hallway_1” and “light.panel_hallway_2” is turned on and got the brightness attribute.
I want to set brightness to both lights and always the same value, i do this today with the below code but i was hoping to use entity id “light.hallway” instead of “light.panel_hallway_1” and “light.panel_hallway_1”.
Also down the road use “states.light.hallway.attributes.brightness” later instead of “states.light.panel_hallway_1.attributes.brightness” because i have a fixture with 6 pulps i want to change to Tradfri and this would come in handy.
automation:
- alias: Adjust brightness hallway
platform: state
entity_id: input_number.hallway_brightness
service: light.turn_on
data_template:
entity_id:
- light.panel_hallway_1
- light.panel_hallway_2
brightness: '{{ trigger.to_state.state | int * 2.55 | round(0) }}'
This is the description from https://home-assistant.io/components/light.template/
set_level
(action) (Optional) Defines an action to run when the light is given a brightness command.
The below code works fine and im getting a entity id named “light.hallway”.
platform: template
lights:
hallway:
friendly_name: "Hallway lighting"
turn_on:
entity_id:
turn_off:
service: light.turn_off
entity_id:
When i try to the code to get brightness something breaks and my entity id “light.hallway” is gone. and i cannot figure out what is wrong.
platform: template
lights:
hallway:
level_template: "{{ states.light.panel_hallway_1.attributes.brightness|int }}"
value_template: "{{ states.light.panel_hallway_1.attributes.brightness|int > 0 }}"
turn_on:
entity_id:
turn_off:
entity_id:
set_level:
data_template:
brightness: "{{ brightness }}"
This is the log right after a “hassio homeassistant restart”:
2017-10-18 08:37:11 ERROR (MainThread) [homeassistant.components.light.template] UndefinedError: 'None' has no attribute 'attributes'
2017-10-18 08:37:12 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.6/asyncio/tasks.py", line 179, in _step
result = coro.send(None)
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 381, in async_process_entity
new_entity, self, update_before_add=update_before_add
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 210, in async_add_entity
yield from entity.async_update()
File "/usr/lib/python3.6/asyncio/coroutines.py", line 210, in coro
res = func(*args, **kw)
File "/usr/lib/python3.6/site-packages/homeassistant/components/light/template.py", line 220, in async_update
if state in _VALID_STATES:
UnboundLocalError: local variable 'state' referenced before assignment
2017-10-18 08:37:18 WARNING (MainThread) [homeassistant.setup] Setup of notify is taking over 10 seconds.
2017-10-18 08:37:19 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-10-18 08:37:20 WARNING (MainThread) [homeassistant.setup] Setup of media_player is taking over 10 seconds.
2017-10-18 08:37:21 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
2017-10-18 08:37:34 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds.
2017-10-18 08:37:48 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Total udgift, the state is unknown.
2017-10-18 08:37:48 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template Affugter effekt, the state is unknown.
