Surely this can be translated into a sensor that can be used as a utility meter…?
An official oil sensor in the energy dashboard would be great, but maybe it’s possible to just mask it as a gas sensor instead, and then display it in the dashboard?
So, I have a daily decreasing number which I’d like to turn into an increasing sensor for the utility meter - should that be possible?
Yes it is possible. What you probably have to do is to create sensor that will calculate gas usage based on oil consumption. I created sensor that calculate gas usage based on furnace running time. This is my example but maybe it can point you in the right direction.
First I created a sensor that will calculate furnace running time in sensors.yaml file like this
### Buderus running time daily
- platform: history_stats
name: Buderus On Time Today
entity_id: binary_sensor.buderus_kessel_betrieb_1_stufe
state: "on"
type: time
start: '{{ now().replace(hour=0).replace(minute=0).replace(second=0) }}'
end: '{{ now() }}'
In template.yaml I use this code to calculate gas consumption based on running time
