Help needed - Zigbee lights and Friends of Hue Senic switches
Hello Guys,
I am new to home assistant and facing multiple problems that I cant find solution for.
My config:
  • Home Assisntant Green as I can’t program
  • Philips Hue Hubs
  • Conbee III zigbee dongle
  • Senic Friends of Hue Switches
So how can I set up that if I press a button on a switch, then a certain light setup happens.
I have tried multiple ways:
  1. Doing automation, so when a press on the button happens, the lights are triggered to set a specific status, like brightness.
  2. Doing automation, so when a person the button happens, it sets a scene
Tried adding the lights directly into HA and using Hue just to manage the switches.
Tried adding the lights through Hue as well.
The problem I face is that let’s say I want to turn on 10 lights by the press of a button, but sometimes few lights remain off. Or when I try to turn lights off, some remains on. This issue is driving me nuts.
The task should be simple, yet it does not work.
Any help how to solve the very simple task of turning on and off multiple lights by a press of a button on a physical switch. I would appreciate it.
Thank you
