Hey everybody! I don’t know if this post is in the right spot. If it’s not, please let me know so I can post in the correct place!
I’m new to HA and I have just enough knowledge to get myself into trouble, which I have done… I had a Zwave network going that failed after a few weeks and I tried to restart it. I looked into it and saw there was a UI version of Zwave JS, so I tried to shift over to that. When I downloaded it, my memory usage and CPU usage went through the roof! So much so that I the system would crash. The instance in my VM was still running but the website wasn’t reachable. I’ve resulted to restarting my HA instance on VirtualBox to get back, but it only stays up for a few minutes. I didn’t need the zwave interface too badly, so I deleted all the Zwave services and add ons from my instance. My HA instance crashes and I can see my CPU and RAM are maxed out. This is WAAAAAAAAY over my head! Is there anyone out there that can help? My computer knowledge is from the “old school” industrial sector. Very different from HA or anything like it.
If you can help, I’d very much appreciate it! Let me know what you need and I’ll get it to you!
Thank you so much!!
A little information about your setup would be helpful, like how much ram have you given the VM and how many CPUs.
Are you running Alexa Media Player too?
Hi Wally,
I’m running on a windows machine in VirtualBox with 2 CPUs and 3 Gig of RAM. No Alexa Media Player, but I am using Google Home as an assistant. It looks like it uses around 1.5Gig of memory at startup and then levels off before starting a slow climb to max.
You can not use the hypervisor’s statistic to tell you anything about the VM.
The VM will use the RAM as cache, because it is way faster than the storage.
Cache can be released quickly to free RAM for other usage, but the hypervisor can not see what the RAM in the VM is used for, so it is just “used up”.
So, is there anything else I can look at to see what is causing the system to crash?
Here’s a copy of the logs from resetting of the VM:
2024-10-13 13:41:01.500 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-13 13:41:01.502 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spook_inverse which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-13 13:41:01.504 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartthinq_sensors which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-13 13:41:01.506 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartthings which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-13 13:41:01.508 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pyscript which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-13 13:41:01.510 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pirateweather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-13 13:41:01.512 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ge_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-13 13:41:01.514 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration mbapi2020 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-13 13:41:01.515 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spook which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-13 13:41:01.519 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-13 13:41:01.521 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spotcast which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-13 13:41:02.381 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2024-10-13 13:41:02.522 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=198 from 2024-10-13 17:11:50.305118)
2024-10-13 13:41:07.471 WARNING (ImportExecutor_0) [slixmpp.stringprep] Using slower stringprep, consider compiling the faster cython/libidn one.
2024-10-13 13:41:07.731 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'ge_home' calls async_forward_entry_setup for integration, ge_home with title: [email protected] and entry_id: c2cc3fe0bbd8d73e6db74ba5443daeec, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead at custom_components/ge_home/update_coordinator.py, line 180: await self.hass.config_entries.async_forward_entry_setup(, please report it to the author of the 'ge_home' custom integration
2024-10-13 13:41:10.805 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module with args ('.climate', 'custom_components.smartthings') inside the event loop by custom integration 'smartthings' at custom_components/smartthings/__init__.py, line 306: platform_module = importlib.import_module( (offender: /config/custom_components/smartthings/__init__.py, line 306: platform_module = importlib.import_module(), please report it to the author of the 'smartthings' custom integration
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#import_module
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever
self._run_once()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once
handle._run()
File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 742, in async_setup_locked
await self.async_setup(hass, integration=integration)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 594, in async_setup
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/smartthings/__init__.py", line 165, in async_setup_entry
broker = DeviceBroker(hass, entry, token, smart_app, devices, scenes)
File "/config/custom_components/smartthings/__init__.py", line 295, in __init__
self._assignments = self._assign_capabilities(devices)
File "/config/custom_components/smartthings/__init__.py", line 306, in _assign_capabilities
2024-10-13 13:41:10.862 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.refrigerator_freezer_temperature_measurement (<class 'custom_components.smartthings.sensor.SmartThingsSensor'>) is using native unit of measurement 'None' which is not a valid unit for the device class ('temperature') it is using; expected one of ['°C', 'K', '°F']; Please update your configuration if your entity is manually configured, otherwise report it to the author of the 'smartthings' custom integration
2024-10-13 13:41:10.862 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.refrigerator_freezer_thermostat_cooling_setpoint (<class 'custom_components.smartthings.sensor.SmartThingsSensor'>) is using native unit of measurement 'None' which is not a valid unit for the device class ('temperature') it is using; expected one of ['°C', 'K', '°F']; Please update your configuration if your entity is manually configured, otherwise report it to the author of the 'smartthings' custom integration
2024-10-13 13:41:10.862 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.refrigerator_cooler_temperature_measurement (<class 'custom_components.smartthings.sensor.SmartThingsSensor'>) is using native unit of measurement 'None' which is not a valid unit for the device class ('temperature') it is using; expected one of ['°C', 'K', '°F']; Please update your configuration if your entity is manually configured, otherwise report it to the author of the 'smartthings' custom integration
2024-10-13 13:41:10.863 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.refrigerator_cooler_thermostat_cooling_setpoint (<class 'custom_components.smartthings.sensor.SmartThingsSensor'>) is using native unit of measurement 'None' which is not a valid unit for the device class ('temperature') it is using; expected one of ['°C', 'K', '°F']; Please update your configuration if your entity is manually configured, otherwise report it to the author of the 'smartthings' custom integration
2024-10-13 13:41:13.503 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_default_certs with args (<ssl.SSLContext object at 0x7f136816d550>, <Purpose.SERVER_AUTH: _ASN1Object(nid=129, shortname='serverAuth', longname='TLS Web Server Authentication', oid='1.3.6.1.5.5.7.3.1')>) in /usr/local/lib/python3.12/ssl.py, line 713: context.load_default_certs(purpose) inside the event loop; This is causing stability issues. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#load_default_certs
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
File "/usr/local/lib/python3.12/site-packages/gehomesdk/clients/base_client.py", line 132, in async_run_client
await self._async_run_client()
File "/usr/local/lib/python3.12/site-packages/gehomesdk/clients/websocket_client.py", line 110, in _async_run_client
async with websockets.connect(self.endpoint, compression=None) as socket:
File "/usr/local/lib/python3.12/site-packages/websockets/legacy/client.py", line 635, in __aenter__
return await self
File "/usr/local/lib/python3.12/site-packages/websockets/legacy/client.py", line 654, in __await_impl__
_transport, protocol = await self._create_connection()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1149, in create_connection
transport, protocol = await self._create_connection_transport(
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1173, in _create_connection_transport
transport = self._make_ssl_transport(
File "/usr/local/lib/python3.12/asyncio/selector_events.py", line 83, in _make_ssl_transport
ssl_protocol = sslproto.SSLProtocol(
File "/usr/local/lib/python3.12/asyncio/sslproto.py", line 295, in __init__
sslcontext = _create_transport_context(
File "/usr/local/lib/python3.12/asyncio/sslproto.py", line 55, in _create_transport_context
sslcontext = ssl.create_default_context()
File "/usr/local/lib/python3.12/ssl.py", line 713, in create_default_context
2024-10-13 13:41:14.197 WARNING (MainThread) [custom_components.ge_home.update_coordinator] Could not find appliance D828C9A3961B in known device list.
The homeassistant.log.1 file in the config library.
It is the log from the previous run.
Hi Wally,
I’m not sure what you’re saying. Do I need to find this log or is this the name of the log I displayed. I apologize for being so under educated. I’m trying to learn as much and as quickly as possible! Thank you for your help!
You need to find that file and open/download it.
It is a text file and the last couple of lines might give a clue about what is wrong.
I’m trying to find it. I’m not sure how. I’m sorry I don’t have the knowledge to just grab it.
Hi there, I found the log here is the error I found.
2024-10-15 13:52:02.965 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_default_certs with args (<ssl.SSLContext object at 0x7f6f9b1fbcd0>, <Purpose.SERVER_AUTH: _ASN1Object(nid=129, shortname='serverAuth', longname='TLS Web Server Authentication', oid='1.3.6.1.5.5.7.3.1')>) in /usr/local/lib/python3.12/ssl.py, line 713: context.load_default_certs(purpose) inside the event loop; This is causing stability issues. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
return await self
context.load_default_certs(purpose)```
You might need to post a bit more of the log around that snippet.
Here is the entire log. My email was in there so I changed it to [email protected]. Also, the last error in the log is new. Everything else was there before. Let me know if you see anything!
Thanks again!
2024-10-15 18:07:02.572 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:07:02.573 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spook_inverse which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:07:02.574 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartthinq_sensors which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:07:02.574 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartthings which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:07:02.575 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pyscript which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:07:02.575 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pirateweather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:07:02.575 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ge_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:07:02.576 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration mbapi2020 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:07:02.576 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spook which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:07:02.577 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:07:02.577 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spotcast which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:07:04.797 WARNING (ImportExecutor_0) [slixmpp.stringprep] Using slower stringprep, consider compiling the faster cython/libidn one.
2024-10-15 18:07:04.886 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'ge_home' calls async_forward_entry_setup for integration, ge_home with title:[email protected] and entry_id: c2cc3fe0bbd8d73e6db74ba5443daeec, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead at custom_components/ge_home/update_coordinator.py, line 180: await self.hass.config_entries.async_forward_entry_setup(, please report it to the author of the 'ge_home' custom integration
2024-10-15 18:07:05.162 ERROR (SyncWorker_9) [custom_components.spotcast.helpers] spotify integration not found
2024-10-15 18:07:07.580 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_default_certs with args (<ssl.SSLContext object at 0x7f0e9ecc6ad0>, <Purpose.SERVER_AUTH: _ASN1Object(nid=129, shortname='serverAuth', longname='TLS Web Server Authentication', oid='1.3.6.1.5.5.7.3.1')>) in /usr/local/lib/python3.12/ssl.py, line 713: context.load_default_certs(purpose) inside the event loop; This is causing stability issues. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
return await self
2024-10-15 18:07:08.194 WARNING (MainThread) [custom_components.ge_home.update_coordinator] Could not find appliance D828C9A3961B in known device list.
2024-10-15 18:11:47.991 WARNING (MainThread) [homeassistant.core] Task <Task pending name='service homeassistant.restart' coro=<_async_admin_handler() running at /usr/src/homeassistant/homeassistant/helpers/service.py:1099> wait_for=<Task pending name='admin service homeassistant.restart' coro=<async_setup.<locals>.async_handle_core_service() running at /usr/src/homeassistant/homeassistant/components/homeassistant/__init__.py:213> wait_for=<Future pending cb=[Task.task_wakeup()]> cb=[set.remove(), Task.task_wakeup()]> cb=[set.remove()]> was still running after final writes shutdown stage; Integrations should cancel non-critical tasks when receiving the stop event to prevent delaying shutdown
We do not need the email and you should change line 2024-10-15 18:07:04.886 too
It looks like Home Assistant is set to restart, but the reason why is not in the log.
The GE Home integration is complaining about a missing device and the Spotify integration is not installed, but HA have references to it.
I am not sure these can be the cause, but try to correct them and see.
I’m not sure why the GE Home integration is missing a device. I only have one and it hasn’t changed. I believe the Spotify integration isn’t working is because I disabled it and it has things outside of the integration. Not sure about it though. UGH…
Here is the latest log:
2024-10-15 18:11:54.225 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:11:54.225 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spook_inverse which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:11:54.225 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartthinq_sensors which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:11:54.225 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartthings which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:11:54.226 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pyscript which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:11:54.226 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pirateweather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:11:54.226 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ge_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:11:54.226 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration mbapi2020 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:11:54.226 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spook which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:11:54.226 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:11:54.226 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spotcast which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 18:11:55.955 WARNING (ImportExecutor_0) [slixmpp.stringprep] Using slower stringprep, consider compiling the faster cython/libidn one.
2024-10-15 18:11:56.006 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'ge_home' calls async_forward_entry_setup for integration, ge_home with title: [email protected] and entry_id: c2cc3fe0bbd8d73e6db74ba5443daeec, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead at custom_components/ge_home/update_coordinator.py, line 180: await self.hass.config_entries.async_forward_entry_setup(, please report it to the author of the 'ge_home' custom integration
2024-10-15 18:11:59.743 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_default_certs with args (<ssl.SSLContext object at 0x7fec3a2727d0>, <Purpose.SERVER_AUTH: _ASN1Object(nid=129, shortname='serverAuth', longname='TLS Web Server Authentication', oid='1.3.6.1.5.5.7.3.1')>) in /usr/local/lib/python3.12/ssl.py, line 713: context.load_default_certs(purpose) inside the event loop; This is causing stability issues. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
return await self
2024-10-15 18:12:00.452 WARNING (MainThread) [custom_components.ge_home.update_coordinator] Could not find appliance D828C9A3961B in known device list.
2024-10-15 18:24:33.128 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'spotcast' calls `async_add_job`, which is deprecated and will be removed in Home Assistant 2025.4; Please review https://developers.home-assistant.io/blog/2024/03/13/deprecate_add_run_job for replacement options at custom_components/spotcast/__init__.py, line 150: hass.async_add_job(get_devices()), please create a bug report at https://github.com/fondberg/spotcast/issues
2024-10-15 18:24:33.814 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
File "/config/custom_components/spotcast/helpers.py", line 122, in run
return await loop.run_in_executor(executor, pfunc)
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/spotcast/__init__.py", line 146, in get_devices
resp = get_spotify_devices(spotify_media_player)
TypeError: get_spotify_devices() missing 1 required positional argument: 'hass'
2024-10-15 18:24:38.380 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
2024-10-15 18:32:19.138 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
