Help! Notify not working
Hi, I posted earlier that telegram wasn’t working but now it seems all of my notifications aren’t working. Originally all of my notification options were working but now they have all stopped. I have gone as far as a fresh install of hassbian. I did though copy the yaml files back in. I think my notify configuration is correct as it was working. I was using notify: !include yamls/notifications.yaml but to trouble shoot I changed to the basic
`notify:
  • platform: pushbullet
    api_key: xxx
in the .yaml I think its formatted correctly but it does’t seem to be inserting correctly. Does anyone have any ideas? I’ve searched for hours but can’t get it to work.
This is the error listed by home assistant
17-04-02 19:28:01 ERROR (MainThread) [homeassistant.setup] Not initializing notify.pushbullet because could not install dependency pushbullet.py==0.10.0
17-04-02 19:28:01 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform notify.pushbullet: Could not install all requirements.
17-04-02 19:28:01 ERROR (MainThread) [homeassistant.components.notify] Unknown notification service specified
Help is much appreciated
Did you try installing pushbullet.py manually?
~Cheers
I have, these are the commands I used
can you suggest another way?
Try to add it like htis.
notify:
- name: xiaomi
api_key: MyKey
pip install pushbullet.py
EDIT:
I don’t know if hassbian is using a virtualenv tho. Maybe you have to switch to that first.
~Cheers
I’m a bit of a noob, can you tell me how switch to the virtualenviroment?
I tried how you have formatted that but it just gives me further errors
Yes absolutly don’t worry. I just need to verify something as I am not running hassbian myself. Is there a directory /srv/homeassistant/bin on your machine with a executable activate?
~Cheers
yes there are three activate files in there blank, .csh and .fish
cool so you just do:
. /srv/homeassistant/bin/activate
deactivate
~Cheers
If you run into some permission problems you might need to switch to the homeassistant user first.
sudo su - homeassistant
~Cheers
I’m giving you a virtual internet hug right now! It worked! Thanks for your help!!
No problem that’s what this forum is for!
~Cheers
