Team,
I have my own certificate authority for the internal devices. I do NOT want to open to duckdns or exernal internet.
I want HomeAssistant to be esposed on https:// not http://
I’ve read instructions here HTTP - Home Assistant (home-assistant.io) and I have created a signed cert for homeassistant.
I’ve got the decrypted private key and put them in the /ssl/ folder.
Then I added
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
Now the fullchain is root cert - intermediate cert - homeassistant cert one after the other
privkey is the decripted homeassistant private key
the config is validated and I can restart homeassistant…
… but…
… I always end up in safe mode AND the https does NOT work. I can only access via http
what am I doing wrong? I’m following all the instructions
thanks
M
