Help please for polling BMW Connected Drive respectfully & charging my BMW i3 EV to max 85% in my cheap electricity supply times
Very recent to Home Assistant (1 week). I have some automations setup & I would be grateful for feedback from some savvy programmers to simplify my code and remove any obvious bloat or mistakes that may be present. :slight_smile:
Car Charging (BMW i3)
Charge my car to max 85% only in my off peak electricity times. It’s a BMW i3 and I’m unable to set a max charge limit within the vehicle, so I poll BMW API to return the charge level. My cheap electricity is between 23.30pm and 05.30am. When the car is plugged in (usually after 5pm) I want the car to wait until my cheap electricity times start and only charge to 85%
I have an API setup for the car (BMW Connected drive) in HA, which polls BMW for various statuses of the car, one of these returned is battery level (SOC).
Note: BMW connected drive rejects API calls if too many requests (100?) in a 24hr period (gets reset around 00.00 UMT). I have disabled HA Cloud auto update from Integrations (default was 5 mins) and THINK I have manually set updates to every 30 mins between 5.30am-23.30pm (36 requests) and every 6 mins during cheap charging window (23.30pm to 5.30am - 60 requests).
The EV charger is programmed (outside of HA) to only deliver power between 23.30-5.30am when in Eco+ mode. When it is outside of the cheap charging times but in Eco+ mode, the charging is paused. I can control the charger in HA to change the mode e.g. Eco+ & Stop.
Here is what I have setup already.
Automation 1 - Poll the BMW server to get car statuses (e.g. charge level, door lock status, etc) every 30 mins between 5.30am and 23.30pm (36 requests in period)
alias: i3S Poll BMW Server Every 30 mins [6am-11.30pm]
description: Poll BMW Servers every 30 mins (not charging)
  - platform: time_pattern
    minutes: /30
condition:
  - condition: time
    after: "06:00:00"
    before: "23:30:00"
  - service: homeassistant.update_entity
    data: {}
      entity_id: sensor.i3s_120_remaining_battery_percent
mode: single
Automation 2 - Poll the BMW server to get the car status every 6 mins between 23.30pm and 05.30am (60 requests in period) - this will make sure the sampling rate from BMW is higher, to help reach the 85% charge level more accurately in Automation 3 and not overshoot it by much.
alias: i3S Poll BMW Server Every 6 mins [11.30pm-5.30am]
description: Poll BMW Servers every 6 mins (when charging)
    minutes: /6
condition:
  - condition: time
    after: "23:30:00"
    before: "05:54:00"
    data: {}
mode: single
Automation 3
Charge the car if its under 85% SOC & only charge in the cheap electricty window 23.30pm and 05.30am
alias: i3S If SOC > 85% > Stop Charger [/5m Between 23.30-05.30]
description: ""
    minutes: /5
    hours: "*"
    seconds: "0"
    enabled: true
condition:
  - type: is_battery_level
    condition: device
    device_id: (removed)
    domain: sensor
    above: 85
  - condition: time
    after: "23:30:00"
    before: "05:30:00"
    weekday:
      - sun
      - sat
      - fri
      - thu
      - wed
      - tue
      - mon
  - condition: not
    conditions:
      - condition: device
        domain: select
        entity_id: select.myenergi_zappi_charge_mode
        type: selected_option
        option: Stopped
        for:
          hours: 0
          minutes: 0
          seconds: 10
  - device_id: (removed)
    domain: select
    type: select_option
    option: Stopped
    enabled: true
  - service: notify.mobile_app_iphone
      message: Car 85% stop charge
      title: SOC > 85% > Zappi Mode Stop
mode: single
Automation 4
Reset the charger back to Eco+ mode (paused).
alias: i3S Set Zappi Mode Eco+ [09/12/15/18/21 Daily]
description: Set Zappi mode to Eco+ @ 9am/12pm/3pm/6pm/9pm/11pm Daily
  - platform: time
    at: "09:00:00"
    enabled: true
  - platform: time
    at: "12:00:00"
    enabled: true
  - platform: time
    at: "15:00:00"
    enabled: true
  - platform: time
    at: "18:00:00"
    enabled: true
  - platform: time
    at: "21:00:00"
    enabled: true
  - platform: time
    at: "23:00:00"
    enabled: true
condition:
  - condition: not
    conditions:
      - condition: device
        domain: select
        option: Eco+
    domain: select
    type: select_option
    option: Eco+
    enabled: true
      message: Zappi mode changed
      title: i3S Set Zappi Mode Eco+ [09/12/15/18/21 Daily]
mode: single
I think might be polling the BMW API in the condition for Automation 3, but not sure how to check.
condition:
    condition: device
    domain: sensor
    above: 85
Is this where templates come into it?
Do I make a sensor template that equals the last retrieved value of sensor.i3s_120_remaining_battery_percent and then use this in the condition of the automation? That way it doesn’t poll BMW as it just checks a value?
I’m getting confused a bit here … :confused:
Any help appreciated
I am really happy to tell you that the BMW i3 does not need to be restricted to a maximum charge of 85%. The onboard battery management system allows you to charge to 100% without any drawback. In fact, charging to only 85% is likely to cause more problems then you perceive it solves.
The BMW i3 is an exceptional vehicle. It’s not a Nissan leaf or a Tesla.
