I finally have my HA Blue and had a chance to start it. However it never gets past " Preparing Home Assistant". After about 30 minutes I unplugged it and reconnected the power. I can as before see it in the router and get to it with “http://homeassistant.local:8123”.
Anyone have any idea on what I should do now? Is there a way to login to it by the command line without ssh?
Please help if you can as I would really like to use it.
I clicked on the blue circle in the “Preparing Home Assistant” window and found this:
21-04-07 02:33:03 INFO (SyncWorker_4) [supervisor.docker.interface]
Updating image homeassistant/odroid-n2-homeassistant:landingpage
to homeassistant/odroid-n2-homeassistant:2021.3.4
Downloading docker image homeassistant/odroid-n2-homeassistant with tag 2021.3.4.
21-04-07 02:33:18 ERROR (SyncWorker_4) [supervisor.docker.interface]
Can't install homeassistant/odroid-n2-homeassistant: 2021.3.4 ->
500 Server Error for http+docker://localhost/v1.40/images/create? tag=2021.3.4&fromImage=homeassistant%2Fodroid-n2-homeassistant:
Internal Server Error ("Get "https://registry-1.docker.io/v2/":
context deadline exceeded (Client.Timeout exceeded while awaiting headers)").
21-04-07 02:33:18 WARNING (MainThread) [supervisor.homeassistant.core]
Error on Home Assistant installation. Retry in 30sec
21-04-07 02:33:48 INFO (SyncWorker_2) [supervisor.docker.interface]
21-04-07 02:34:03 ERROR (SyncWorker_2) [supervisor.docker.interface]
Can't install homeassistant/odroid-n2-homeassistant:2021.3.4 ->
500 Server Error for http+docker: //localhost/v1.40/images/create?tag=2021.3.4&fromImage=homeassistant%2Fodroid-n2-homeassistant:
Internal Server Error ("Get "https://registry-1.docker.io/v2/": context deadline exceeded (Client.Timeout exceeded while awaiting headers)").
21-04-07 02:34:03 WARNING (MainThread) [supervisor.homeassistant.core]
21-04-07 02:34:33 INFO (SyncWorker_3) [supervisor.docker.interface]
Updating image homeassistant/odroid-n2-homeassistant:landingpage to
21-04-07 02:34:48 ERROR (SyncWorker_3) [supervisor.docker.interface]
500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.3.4&fromImage=homeassistant% 2Fodroid-n2-homeassistant:
Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http:
request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)").
21-04-07 02:34:48 WARNING (MainThread) [supervisor.homeassistant.core]
21-04-07 02:35:18 INFO (SyncWorker_4) [supervisor.docker.interface]
21-04-07 02:35:33 ERROR (SyncWorker_4) [supervisor.docker.interface]
500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.3.4&fromImage=homeassistant%2Fodroid-n2-homeassistant:
Internal Server Error ("Get "https://registry-1.docker.io/v2/": context deadline exceeded").
21-04-07 02:35:33 WARNING (MainThread) [supervisor.homeassistant.core]
21-04-07 02:36:03 INFO (SyncWorker_0) [supervisor.docker.interface]
21-04-07 02:36:18 ERROR (SyncWorker_0) [supervisor.docker.interface]
21-04-07 02:36:18 WARNING (MainThread) [supervisor.homeassistant.core]
This is repeating over and over. Thank you for any assistance someone might have
Dennis
