Apologies…forgot to post the hasso-supervisor log:
20-01-26 06:53:39 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 0 new - 0 remove,
20-01-26 07:53:37 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-01-26 08:26:57 INFO (MainThread) [hassio.host.info] Update local host information,
20-01-26 08:26:57 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1,
20-01-26 08:26:58 INFO (MainThread) [hassio.host.services] Update service information,
20-01-26 08:26:58 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1,
20-01-26 08:26:58 INFO (MainThread) [hassio.host.network] Update local network DNS information,
20-01-26 08:26:58 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager,
20-01-26 09:53:37 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository,
20-01-26 09:53:37 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository,
20-01-26 09:53:38 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-01-26 09:53:39 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 0 new - 0 remove,
20-01-26 10:33:37 INFO (MainThread) [hassio.host.info] Update local host information,
20-01-26 10:33:37 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1,
20-01-26 10:33:38 INFO (MainThread) [hassio.host.services] Update service information,
20-01-26 10:33:38 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1,
20-01-26 10:33:38 INFO (MainThread) [hassio.host.network] Update local network DNS information,
20-01-26 10:33:38 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager,
20-01-26 11:53:38 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-01-26 12:40:17 INFO (MainThread) [hassio.host.info] Update local host information,
20-01-26 12:40:17 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1,
20-01-26 12:40:18 INFO (MainThread) [hassio.host.services] Update service information,
20-01-26 12:40:18 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1,
20-01-26 12:40:18 INFO (MainThread) [hassio.host.network] Update local network DNS information,
20-01-26 12:40:18 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager,
20-01-26 12:53:37 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository,
20-01-26 12:53:37 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository,
20-01-26 12:53:39 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 0 new - 0 remove,
20-01-26 13:53:38 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-01-26 14:46:57 INFO (MainThread) [hassio.host.info] Update local host information,
20-01-26 14:46:57 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1,
20-01-26 14:46:58 INFO (MainThread) [hassio.host.services] Update service information,
20-01-26 14:46:58 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1,
20-01-26 14:46:58 INFO (MainThread) [hassio.host.network] Update local network DNS information,
20-01-26 14:46:58 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager,
20-01-26 15:53:37 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository,
20-01-26 15:53:37 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository,
20-01-26 15:53:38 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-01-26 15:53:39 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 0 new - 0 remove,
20-01-26 16:53:38 INFO (MainThread) [hassio.host.info] Update local host information,
20-01-26 16:53:38 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1,
20-01-26 16:53:38 INFO (MainThread) [hassio.host.services] Update service information,
20-01-26 16:53:38 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1,
20-01-26 16:53:38 INFO (MainThread) [hassio.host.network] Update local network DNS information,
20-01-26 16:53:38 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager,
20-01-26 17:53:37 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files,
20-01-26 17:53:38 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-01-26 18:53:37 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository,
20-01-26 18:53:37 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository,
20-01-26 18:53:39 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 0 new - 0 remove,
20-01-26 19:00:18 INFO (MainThread) [hassio.host.info] Update local host information,
20-01-26 19:00:18 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1,
20-01-26 19:00:18 INFO (MainThread) [hassio.host.services] Update service information,
20-01-26 19:00:18 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1,
20-01-26 19:00:18 INFO (MainThread) [hassio.host.network] Update local network DNS information,
20-01-26 19:00:18 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager,
20-01-26 19:33:29 INFO (MainThread) [main] Stopping Hass.io,
20-01-26 19:33:29 INFO (MainThread) [hassio.api] Stop API on 172.30.32.2,
20-01-26 19:33:29 INFO (MainThread) [hassio.misc.forwarder] Stop DNS forwarding,
20-01-26 19:33:29 INFO (MainThread) [hassio.core] Hass.io is down,
20-01-26 19:33:29 INFO (MainThread) [main] Close Hass.io,
20-01-26 19:33:46 INFO (MainThread) [main] Initialize Hass.io setup,
20-01-26 19:33:46 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 195,
20-01-26 19:33:47 INFO (MainThread) [main] Setup HassIO,
20-01-26 19:33:47 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1,
20-01-26 19:33:47 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1,
20-01-26 19:33:47 WARNING (MainThread) [hassio.dbus.rauc] Host has no rauc support. OTA updates have been disabled.,
20-01-26 19:33:47 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager,
20-01-26 19:33:47 INFO (MainThread) [hassio.host.info] Update local host information,
20-01-26 19:33:47 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1,
20-01-26 19:33:47 INFO (MainThread) [hassio.host.services] Update service information,
20-01-26 19:33:47 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1,
20-01-26 19:33:48 INFO (MainThread) [hassio.host.network] Update local network DNS information,
20-01-26 19:33:48 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager,
20-01-26 19:33:48 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {‘hassio-supervisor’},
20-01-26 19:33:48 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service,
20-01-26 19:33:48 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1,
20-01-26 19:33:48 INFO (SyncWorker_2) [hassio.docker.interface] Attach to homeassistant/armv7-hassio-dns with version 1,
20-01-26 19:33:48 INFO (MainThread) [hassio.misc.forwarder] Start DNS port forwarding to 172.30.32.3,
20-01-26 19:33:48 INFO (SyncWorker_2) [hassio.docker.interface] Restart homeassistant/armv7-hassio-dns,
20-01-26 19:33:51 INFO (SyncWorker_3) [hassio.docker.interface] Attach to homeassistant/intel-nuc-homeassistant with version 0.104.2,
20-01-26 19:33:52 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository,
20-01-26 19:33:52 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository,
20-01-26 19:33:53 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 63 new - 0 remove,
20-01-26 19:33:53 INFO (MainThread) [hassio.addons] Found 0 installed add-ons,
20-01-26 19:33:53 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-01-26 19:33:53 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files,
20-01-26 19:33:53 INFO (MainThread) [hassio.discovery] Load 0 messages,
20-01-26 19:33:53 INFO (MainThread) [hassio.ingress] Load 0 ingress session,
20-01-26 19:33:53 INFO (MainThread) [hassio.secrets] Load Home Assistant secrets: 0,
20-01-26 19:33:53 INFO (MainThread) [main] Run Hass.io,
20-01-26 19:33:53 INFO (MainThread) [hassio.api] Start API on 172.30.32.2,
20-01-26 19:33:53 INFO (MainThread) [hassio.addons] Phase ‘initialize’ start 0 add-ons,
20-01-26 19:33:53 INFO (MainThread) [hassio.core] Hass.io reboot detected,
20-01-26 19:33:53 INFO (MainThread) [hassio.tasks] All core tasks are scheduled,
20-01-26 19:33:53 INFO (MainThread) [hassio.core] Hass.io is up and running,
20-01-26 19:34:08 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker!,
20-01-26 19:34:08 INFO (SyncWorker_2) [hassio.docker.interface] Start homeassistant/intel-nuc-homeassistant,
20-01-26 19:34:14 ERROR (MainThread) [hassio.homeassistant] Home Assistant has crashed!,
20-01-26 19:34:14 ERROR (MainThread) [hassio.tasks] Watchdog Home Assistant reanimation fails!,
