Alphadog
(Jon)
December 6, 2018, 5:06pm
1
I want to use the Network UPS Tools add-on
I see it here in Github https://github.com/hassio-addons/addon-nut and it appears to be part of the official add-ons as instructions say to use this: https://github.com/hassio-addons/repository
But within Hassio I can’t seem to find it to add it. I am fairly new to this, so I am sorry if this is a simple question.
I know once the server is installed, I then need to add the sensor add-on too.
Alphadog
(Jon)
December 6, 2018, 11:04pm
3
Is there anyway to install it other then waiting until some future release date? It seems documented and hasn’t been updated for a few months. Or should i be using some other version of Home Assistant that has more add-ons available?
ludeeus
(Ludeeus)
December 6, 2018, 11:07pm
4
You should wait.
but you could if you really needed clone the repo and do a local build of it (not recomended if you do not know what you are doing)
since it’s been a while since the last update in that repo the local build will most likely fail.
Alphadog
(Jon)
December 7, 2018, 4:51pm
5
I guess i will stick with APC add on for now and use SSH - having other issues with that, so will start a new question.
