I have a curl command to play a live TV channel in Kodi.
- This variation runs successfully from the command line, but does not validate in configuration.yaml:
Command line:
curl -X POST -H "Content-Type: application/json" -d '{"jsonrpc":"2.0","id":"1","method":"Player.Open","params":{"item":{"channelid":46}}}' http://192.168.x.xxx:8080/jsonrpc
Error from the configuration.yaml:
incomplete explicit mapping pair; a key node is missed; or followed by a non-tabulated empty line at line 63, column 46:
... s: curl -X POST -H "Content-Type: application/json" -d '{"jsonrp ...
- This variation validates in configuration.yaml:
curl -X POST '{"jsonrpc":"2.0","id":1,"method":"Player.Open","params":{"item":{"channelid":46}}}' -H 'content-type:application/json;' http://192.168.x.xxx:8080/jsonrpc
But does not run from the command line:
curl: (3) nested brace in URL position 57:
{"error":{"code":-32700,"message":"Parse error."},"id":null,"jsonrpc":"2.0"}
Can anyone offer any suggestions?
