Hi, Can anyone help with this error I get periodically on my Zigbee dongle?
Virtualbox reports it cannot connect the USB.
There is no physical movement of the device causing a disconnect.
If I look at devices after noticing my Zigbee is down, the device is connected in VirtualBox.
ZHA tells me the coordinator isn’t connected. If I restart the integration it fails to load.
I’ve now bought a SKy Connect hoping the Sonoff hardware was the issue.
I’m still having the same errors and my smarthome is now failing the partner test…
My next step would be a complete reinstall but I really hope I can avoid that.
Any suggestions?
Now I know it’s not the coordinator, I hope I can isolate it to:
-HA config
-Virtualbox
-Hardware (host laptop) fault
