Hi.
I’m trying (and failing) to set a battery discharge rate, so I can discharge my giv battery in the evening, before charging it again overnight.
In an Automation, I have a working trigger and condition, but can’t figure out how to get maths into the action, to calculate the required discharge rate. The idea is that at 9:00pm, I check the SoC, work out a suitable discharge rate so it’s down to 20% at 11:30pm, then switch to charging again.
What I have so far:
action: number.set_value
device_id: 9117e75e28fdd3274821c26a73c4dd0c
entity_id: number.givtcp_cexxxxxxxx_battery_discharge_rate
{% set DischargeRate = states('sensor.givtcp_cexxxxxxxx_soc') * 3000 | float %}
{{DischargeRate }}
I've had many error messages as I've played with quotes and alternative structures. The error message for this try is:
Action YAML contains syntax errors, please fix the syntax
Any help much appreciated.
thanks, Dave
" Your example specifies an entity_id and a device_id. Are you trying to set the value of twonumber entities?"
No. I used the graphical editor to provide an example of what’s needed, and it came up with the 2 entries. Then tried to edit it in yaml, and have been fixated on the maths ever since. Staying with just the entity seems logical.
I’ve tried the example you provided (with the value line), and it worked - thank you so much!
Please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. This helps users find answers to similar questions.
