Hello!
I use custom integration which is not supported by its author.
And after update HA to 2024.06 it raises an error
Detected blocking call to open with args ('/usr/local/lib/python3.12/site-packages/pytz/zoneinfo/Africa/Abidjan', 'rb') inside the event loop by custom integration 'lkcomu_interrao' at
custom_components/lkcomu_interrao/_util.py,
line 61: return __import__("inter_rao_energosbyt.api." + type_, globals(), locals(), ("API",)).API (offender: /usr/local/lib/python3.12/site-packages/pytz/__init__.py, line 108: return open(filename, 'rb')),
please create a bug report at https://github.com/alryaz/hass-lkcomu-interrao/issues
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#open Traceback (most recent call last):
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module> sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 190, in run return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete self.run_forever()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever self._run_once()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once handle._run()
File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/setup.py", line 167, in async_setup_component result = await _async_setup_component(hass, domain, config)
File "/usr/src/homeassistant/homeassistant/setup.py", line 449, in _async_setup_component await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/setup.py", line 451, in <genexpr> create_eager_task(
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 37, in create_eager_task return Task(coro, loop=loop, name=name, eager_start=True)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 734, in async_setup_locked await self.async_setup(hass, integration=integration)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 586, in async_setup result = await component.async_setup_entry(hass, self)
File "/config/custom_components/lkcomu_interrao/__init__.py", line 247, in async_setup_entry api_cls = import_api_cls(type_)
File "/config/custom_components/lkcomu_interrao/_util.py", line 61, in import_api_cls return __import__("inter_rao_energosbyt.api." + type_, globals(), locals(), ("API",)).API
Here are lines 60 and 61:
def import_api_cls(type_: str) -> Type["BaseEnergosbytAPI"]:
This is the link for this integration GitHub - alryaz/hass-lkcomu-interrao: Интеграция Home Assistant с ЛК "Интер РАО"
Will anyone help me to fix it, please?
