I need some help: my Home Assistant installation has lost contact with the supervisor.
I’ve been running Home Assistant on a Raspberry Pi 4 for over a year. A few days ago I started getting the message “Cannot load the Supervisor panel!” when I go to Configuration > Add-ons, Backups & Supervisor.
I’ve tried restarting with the HA Configuration > Server Controls > Server Management > RESTART, but this fails to restart. As a last restort I power-cycled the RPi but it did came back in the same state.
Several Zigbee light switches have been dropping out over the last few days, and it was when I investigated this that I noticed the supervisor problem. HA is functioning OK apart from this.
The Observer reports:
Supervisor: Connected Supported: Supported Healthy: Healthy
System Health says:
System Health
error unknown
Home Assistant Community Store
GitHub API ok GitHub Content ok GitHub Web ok GitHub API Calls Remaining 5000 Installed Version 1.23.0 Stage running Available Repositories 1007 Downloaded Repositories 2 Home Assistant Cloud
[MANAGE]
Logged In false Reach Certificate Server ok Reach Authentication Server ok Reach Home Assistant Cloud ok Home Assistant Supervisor
[MANAGE]
error unknown
Lovelace
[MANAGE]
Dashboards 1 Resources 0 Views 5 Mode storage Spotify
Spotify API endpoint reachable ok
The error log includes entries like these:
Logger: homeassistant.setup
Source: helpers/system_info.py:57
First occurred: 17:19:25 (1 occurrences)
Last logged: 17:19:25Error during setup of component usb
File “/usr/src/homeassistant/homeassistant/setup.py”, line 227, in _async_setup_component
result = await task
File “/usr/src/homeassistant/homeassistant/components/usb/init.py”, line 97, in async_setup
await usb_discovery.async_setup()
File “/usr/src/homeassistant/homeassistant/components/usb/init.py”, line 128, in async_setup
await self._async_start_monitor()
File “/usr/src/homeassistant/homeassistant/components/usb/init.py”, line 139, in _async_start_monitor
info = await system_info.async_get_system_info(self.hass)
File “/usr/src/homeassistant/homeassistant/helpers/system_info.py”, line 57, in async_get_system_info
info_object[“supervisor”] = info.get(“supervisor”)
AttributeError: ‘NoneType’ object has no attribute ‘get’
Logger: homeassistant.config_entries
Source: components/hassio/init.py:725
First occurred: 17:19:23 (1 occurrences)
Last logged: 17:19:23Error setting up entry Supervisor for hassio
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 327, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/hassio/init.py”, line 647, in async_setup_entry
coordinator = HassioDataUpdateCoordinator(hass, entry, dev_reg)
File “/usr/src/homeassistant/homeassistant/components/hassio/init.py”, line 725, in init
self.is_hass_os = “hassos” in get_info(self.hass)
TypeError: argument of type ‘NoneType’ is not iterable
Logger: homeassistant.components.hassio.addon_panel
Source: components/hassio/addon_panel.py:75
Integration: Home Assistant Supervisor (documentation, issues)
Last logged: 17:19:23Can’t read panel info:
