Hello all,
First timer here, I finally got around to playing with Home Assistant after reading so much about it, however I’m stuck on my first automation which is not triggering at all.
- id: test123
alias: Startup Notification
- platform: time
at: "20:45:00"
condition:
- condition: time
weekday:
- tue
- wed
- thu
- fri
service: ifttt.trigger
data: {"event":"foyer_light_on"}
I’m not getting any validation errors in the above automations.yaml, the configurations.yaml is:
homeassistant:
latitude: XXX
longitude: YYY
unit_system: metric
time_zone: America/Edmonton
# Configure a default setup of Home Assistant (frontend, api, etc)
#default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
#automation
# IFTTT
ifttt:
key: [hidden]
Through Developer Tools, I can run the ifttt.trigger service just fine but this timer script was just not firing for me last night (Tuesday, Jan. 14).
Any help is appreciated
