Help pulling out State Atrribute
I have a calendar entity that has many attributes, I have taken a snapshot below
message: Stage 6
all_day: false
start_time: 2023-04-21 16:00:00
end_time: 2023-04-21 20:30:00
description:
friendly_name: Loadshedding Local Events
I can pull out the state attribute “start_time” however I would like to ignore the first 8 digits the date and would just like it to returm the time, is this possible? Can I create another sensor and reduce the detail I take from the state attribute?
Thanks in advance
The general answer is that you can use a Template sensor
One option for the template is as follows:
{{ state_attr('calendar.EXAMPLE', 'start_time')[-8:]
A more specific answer is dependent on what your actual goal is.
This would be perfect thank you very much. I am using it in a template card for a dashboard.
Works perfectly!
