I have a problem with a Rpi Zero W using the standard camera.
The system is running MotionEYE and it works excellent in Lovelace as a camera entity.
But when i try to use the camera.play_stream
a error message comes up.
“Failed to call service camera/play_stream. camera.rpicam does not support play stream service”
Is my camera not supported? or do i have to change some settings in the MotionEYE config?
This is my code and it should work.
"entity_id": "camera.rpicam",
"media_player": "media_player.cast_stue",
"format": "hls"
