Help, RasPI HA stuck on update to 2021.4.2
Standard installation with supervisor on a RasPI, kept up to date.
Yesterday I pushed one of the two update buttions in the supervisor screen. Since then nothing seemed to happen and looking hours later, the only screen I got was the original “preparing home Assistant (this can take up to 20 minutes)” screen. This morning , 12 hours later I looked again and still this screen. So accidentally I pushed the animated blue circle to find out that it shows a log (please put a text like "push to view log ") below this circle!).
From the log I suspect the upgrade is stuck in a loop as I see the same messages repeating over and over again. What to do ??
21-04-10 08:31:15 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi3-64-homeassistant:landingpage to homeassistant/raspberrypi3-64-homeassistant:2021.4.2
21-04-10 08:31:15 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi3-64-homeassistant with tag 2021.4.2.
21-04-10 08:35:32 ERROR (SyncWorker_1) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi3-64-homeassistant:2021.4.2 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi3-64-homeassistant:2021.4.2/json: Not Found (“no such image: homeassistant/raspberrypi3-64-homeassistant:2021.4.2: No such image: homeassistant/raspberrypi3-64-homeassistant:2021.4.2”).
21-04-10 08:35:32 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-04-10 08:36:02 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image homeassistant/raspberrypi3-64-homeassistant:landingpage to homeassistant/raspberrypi3-64-homeassistant:2021.4.2
21-04-10 08:36:02 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi3-64-homeassistant with tag 2021.4.2.
21-04-10 08:40:27 ERROR (SyncWorker_3) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi3-64-homeassistant:2021.4.2 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi3-64-homeassistant:2021.4.2/json: Not Found (“no such image: homeassistant/raspberrypi3-64-homeassistant:2021.4.2: No such image: homeassistant/raspberrypi3-64-homeassistant:2021.4.2”).
21-04-10 08:40:27 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-04-10 08:40:57 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image homeassistant/raspberrypi3-64-homeassistant:landingpage to homeassistant/raspberrypi3-64-homeassistant:2021.4.2
21-04-10 08:40:57 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi3-64-homeassistant with tag 2021.4.2.
21-04-10 08:45:22 ERROR (SyncWorker_3) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi3-64-homeassistant:2021.4.2 -> 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi3-64-homeassistant:2021.4.2/json: Not Found (“no such image: homeassistant/raspberrypi3-64-homeassistant:2021.4.2: No such image: homeassistant/raspberrypi3-64-homeassistant:2021.4.2”).
21-04-10 08:45:22 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-04-10 08:45:52 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/raspberrypi3-64-homeassistant:landingpage to homeassistant/raspberrypi3-64-homeassistant:2021.4.2
21-04-10 08:45:52 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi3-64-homeassistant with tag 2021.4.2.
Regards Bernie
