I noticed that push notifications stopped working on my phone. I wanted to start fresh on this so I emptied out my ios.conf and ios_devices.conf (is this even still used?).
On my phone I connect and press Enable notifications in the setting’s pane and then “Allow” in the pop-up dialog. In the Notification Settings view I see “Not registered for remote notifications” but, I can see my phone in the ios.conf.
I wanted to test if it was working anyways so I try to call the notify.iosapp service as follows:
{"message": "test"}
I get the following error:
16-12-07 20:00:45 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_call_id=1977006640-11, service_data=message=test, domain=notify, service=iosapp>
16-12-07 20:00:46 ERROR (Thread-10) [homeassistant.components.notify.ios] No target parameter was found in the notification payload.
16-12-07 20:00:46 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1977006640-11>
A little unclear to me what to put for target and I thought this field was optional?
Any idea why my phone is reporting as unregistered?
I looked in to this a little more, I think this error message is because ios.enabled_push_ids() is returning None. This seems to confirm that it failed to register my phone but, I still don’t know why the phone isn’t registering…
I seem to have things working now… I uninstalled app from phone, cleared ios.conf and started over. My mistake the first time was probably not reinstalling the iOS app before wiping the HA config.
