Hello Guys.
I need some help. I can’t configure the thermostat as it is installed.
It is a Tuya thermostat, It’s integrated OK.
It’s supposed to control a shelly (that controls a valve) but I can’t do it with a thermostat.
Basically, what I want to do is turn on the valve when “current_temperature” is lower than “temperature” (the set value)
With automation, I can’t compare the two values because they are not entities. These are attributes of the entity climate.oficina
hvac_modes:
- "off"
- heat_cool
- heat_cool
min_temp: 5
max_temp: 95
target_temp_step: 0.5
preset_modes:
- program
current_temperature: 21.5
temperature: 30
preset_mode: null
friendly_name: Oficina
supported_features: 401
Any Ideas?
Thanks!!!
