Help Sending Map Attachment as Mobile Notification
I would like to send iOS notifications map attachment, with all recent lightning strikes using the blitzortung community add-on.
I have found an avenue to this approach using a blueprint that includes the ability to send map attachment, but this blueprint requires lon,lat coordinates, since I can’t find a way to get this info I’m stuck. I do have an idea for how to do it, just no idea how to attach to a notification. anybody had success with this?
type: map
entities:
  - device_tracker.jos_iphone
  - device_tracker.garys_iphone
geo_location_sources:
  - all
I did find out where the coordinates are stored but with no knowledge of getting the info out I need. states.geo_location
a map attachment on IOS can only have 2 or less pins. So you will be limited by this.
I am also not completely sure what you want to do.
Do you want to send a map with two pins for the two device tracker you mentioned?
If you want to do that, you can use this template
{{(state_attr("device_tracker.jos_iphone","latitude") ~","~state_attr("device_tracker.jos_iphone","longitude")) ~ ",,"}}
for the first pin input on the blueprint
and
{{(state_attr("device_tracker.garys_iphone","latitude") ~","~state_attr("device_tracker.garys_iphone","longitude")) ~ ",,"}}
for the second one.(Just paste those in the correseponding textboxes of the blueprint). You also have to check Enable Second Pin. This will place a pin on each devices location. Remember that you can not just send a map from homeassistant, you can only specify at which location you want to have a pin, the rest is done on the Iphone itself.
If you want to put a pin for each lightning you are out of luck. But you could place a pin for the last one (at least I think that it is the last one?) with this template
{{(state_attr("sensor.blitzortung_lightning_distance","lon") ~","~state_attr("sensor.blitzortung_lightning_distance","lat")) ~ ",,"}}
If you have any questions just ask!
PS.: If you are wondering why the templates have the ", , " at the end… this is to trick my own blueprint to accept this as a input. (If we would not have those the output of the template would be treated as a list but the blueprint assumes it is a string)
I would like to send iOS notification map attachment, with all recent lightning strikes using the blitzortung community add-on.
service: notify.notify
  message: >-
    Lightning observed {{
    (states.sensor.blitzortung_lightning_distance.state|float*0.621371)|round(0)
    }}mi from Home. Press Hold for map
    action_data:
      latitude: "{{state_attr('sensor.blitzortung_lightning_azimuth','lat')}}"
      longitude: "{{state_attr('sensor.blitzortung_lightning_azimuth','lon')}}"
